lights all messed up! help!
so i have been having an ongoing problem with the truck's taillights and turn signals, i just replaced the turn signal switch and its acting even worse.
the right rear turn signal isnt working, the taillights are not working, the break lights are not working, the sidemarkers and parking lights are not working and now the parking lights and sidemarkers blink every few seconds when everything is off
i have replaced:
turn signal switch
headlight switch
both taillights
flasher
parking light sockets
all bulbs
i am completely at a loss for where to look next, any help is appreciated
i have replaced:
turn signal switch
headlight switch
both taillights
flasher
all bulbs
The parking lights are a simple circuit, I would start troubleshooting that. 1st thing to do is pull the headlight switch again. Leave it connected. Take a testlight or voltmeter, and check for voltage on the tan/white wire. You should have power. If you don't check the fuse. If the fuse is good, check the tan/white and see if it's melted in two somewhere.
If you have voltage on the tan/white, then pull the switch either half-way or all the way out, and then check for voltage on the brown wire. You should have it there. If not, check the headlight switch wiring plug, it could be melted.
If you have voltage on the brown, wire, then go out and any where you find a brown wire, it should be the parking lights wire, and try to check for voltage. A good place to check would be after it goes through the large firewall plug.
Yes...back there is where the trailer wiring harness connects into the lighting harness...that can get hacked up over time and cause all kinds of problems.
I finally got a chance to pull it apart and I am not seeing any tan or white wires, there is a blue/red, black/pink, red/yellow, 2 brown, 2 green/yellow, yellow with blue dots, and black/orange
i also do have LED taillights on it at the moment, i replaced the old ones when i thought they were the problem, and i do have an electronic flasher, it worked before though so i would be suprised if that had much to do with it
Bk/Pk: Backup
R/Y: can't find
Br: Tail lights
G/Y: can't find
Y/B: can't find
Bk/Or: can't find
Here's what you should have:
Brown: Tail
Or/Light Blue: RH Stop
Light Green/Or: LH Stop
Bk/Pk: Backup
Sounds like a good plan. A wise man once said "Well, you're a good man, lieutenant. A good man always knows his limitations."
