No Start over Memorial Day Weekend
#31
With the SGII we Look at ICP & IPR% with these 2 numbers you can see a HPO Problem
Basicaly with Gauges you can see what part of the operating is Out of Spec it keeps the Shops in check so they dont sell you unneeded parts & service and also you have the option to repair yourself if its something you want to tackle on your own
And most shops wont spend the time to flush cooling system over and over like some of these trucks Need to get the junk out
But sounds like they might be an honest shop so they should be Fair with you
#32
Thanks,
Todd
#33
#34
With the SGII I checked the voltage while starting. Before I attempted to start the truck it read 11.9v. When I was cranking it dropped some, with the lowest voltage showing as 8.8v. Is this normal, or should the voltage be higher while cranking? I charged both batteries to 100% a couple days ago and since the truck won't start I've only been draining it since due to cranking and the engine compartment hood light being on.
#35
AP%
Accelerator Pedal Position (%) TXD: 07E02209D4 RXF: 0462050906D4 RXD: 3008 MTH: 000100020000 NAM: AP%
BAT
Battery Voltage (Volts) TXD: 07E0221172 RXF: 046205110672 RXD: 3008 MTH: 000100100000 NAM: BAT
BST
Boost (Untested) TXD: 686AF1010B RXF: 0441850B0000 RXD: 2808 MTH: 00910064FF88 NAM: BST
CVI
VREF (My notes indicate that this is the Calibration VTXD: 07E0221155 RXF: 046205110655 RXD: 3010 MTH: 000133330000 NAM: CVI
EBP
Exhaust Back Pressure TXD: 07E0221445 RXF: 046285140645 RXD: 3010 MTH: 001D00500000 NAM: EBP
EGR EGR Duty Cycle (Percent) TXD: 07E022166E RXF: 04620516066E RXD: 3010 MTH: 006440000000 NAM: EGR
EGV EGR Valve Position (Volts 0-5) TXD: 07E022167E RXF: 04620516067E RXD: 3010 MTH: 000133330000 NAM: EGV
EOT
Engine Oil Temp. TXD: 07E0221310 RXF: 046245130610 RXD: 3010 MTH: 00090005F05F ( UNAM: EOT
ERT Engine Run Time TXD: 07DF011F RXF: 0441051F RXD: 2810 MTH: 0001003C0000 NAM: ERT (Mi
ETP
EGR Throttle Position Control Signal TXD: 07E022096C RXF: 04620509066C RXD: 3010 MTH: 00647FFF0000 NAM: ETP
EVD
EGR Valve Position Desired (%) TXD: 07E02209D2 RXF: 0462050906D2 RXD: 3010 MTH: 00647FFF0000 NAM: EVD
EVM
EGR Valve Position Measured (%) TXD: 07E02209FE RXF: 0462050906FE RXD: 3010 MTH: 00647FFF0000 NAM: EVM
EVP
EGR Valve Position (mm) TXD: 07E022096A RXF: 04620509066A RXD: 3010 MTH: 000100010000 NAM: EVP
FI1
Fuel Injector #1 Commanded on (On/0ff) TXD: 07E02209EF RXF: 0462250906EF RXD: 3001 MTH: 000100010000 NAM: FI1
FI2
Fuel Injector #2 Commanded on (On/0ff) TXD: 07E02209EF RXF: 0462250906EF RXD: 3101 MTH: 000100010000 NAM: FI2
FI3
Fuel Injector #3 Commanded on (On/0ff) TXD: 07E02209EF RXF: 0462250906EF RXD: 3201 MTH: 000100010000 NAM: FI3
FI4
Fuel Injector #4 Commanded on (On/0ff) TXD: 07E02209EF RXF: 0462250906EF RXD: 3301 MTH: 000100010000 NAM: FI4
FI5
Fuel Injector #5 Commanded on (On/0ff) TXD: 07E02209EF RXF: 0462250906EF RXD: 3401 MTH: 000100010000 NAM: FI5
FI6
Fuel Injector #6 Commanded on (On/0ff) TXD: 07E02209EF RXF: 0462250906EF RXD: 3501 MTH: 000100010000 NAM: FI6
FI7
Fuel Injector #7 Commanded on (On/0ff) TXD: 07E02209EF RXF: 0462250906EF RXD: 3601 MTH: 000100010000 NAM: FI7
FI8
Fuel Injector #8 Commanded on (On/0ff) TXD: 07E02209EF RXF: 0462250906EF RXD: 3701 MTH: 000100010000 NAM: FI8
FL
Fuel Level TXD: 007E02216C1 RXF: 0462451606C1 RXD: 3010 MTH: 000101480000 NAM: FL
FLP
FICM Logic Power (Volts) (Should be 12 volts) TXD: 07E02209CF RXF: 0462450906CF RXD: 3010 MTH: 0064010000000 NAM: FLP
FMP
FICM Main Power (Volts) (Should be 47-48) TXD: 07E02209D0 RXF: 0462450906D0 RXD: 3010 MTH: 0064010000000 NAM: FMP
FPW
Fuel Injector Pulse Width (microseconds) TXD: 07E0221410 RXF: 046205140610 RXD: 3010 MTH: 000800010000 NAM: FPW
FSS
Fan Speed Sensor (RPM) TXD: 07E022099F RXF: 04620509069F RXD: 3010 MTH: 000100040000 NAM: FSS
FVP
FICM Vehicle Power (Volts) (Should be 12 Volts) TXD: 07E02209CE RXF: 0462450906CE RXD: 3010 MTH: 0064010000000 NAM: FVP
HPR
Horse Power TXD: 00 RXF: 400080000000 RXD: 0000 MTH: 000A00240000 NAM: HPR
IA2
Intake Air Temperature 2 (Fahrenheit) TXD: 07E02216A8 RXF: 0462051606A8 RXD: 3010 MTH: 000100010000 NAM: IA2
ICP
Inj. Control Press. TXD: 07E0221446 RXF: 046205140646 RXD: 3010 MTH: 003900640000 NAM: ICP
IPR %IPR Duty Cycle TXD: 07E0221434 RXF: 046285140634 RXD: 3008 MTH: 0DCA03E8000A NAM: IPR %
ITM
Injector Timing Before Top Dead Center (Degrees) TXD: 07E02209CC RXF: 0462850906CC RXD: 3010 MTH: 000A00400000 NAM: ITM
MFD
Mass Fuel Desired TXD: 07E0221412 RXF: 046245140612 RXD: 3010 MTH: 006400100000 NAM: MFD
PSI
Manifold Absolute Pressure TXD: 07E0221440 RXF: 046285140640 RXD: 3010 MTH: 012203200000 NAM: PSI
PSI Boost TXD: 07E0221440 RXF: 046285140640 RXD: 3010 MTH: 012203200000 NAM: PSI
SYC
Crankshaft Position Sensor TXD: 07E02209CD RXF: 0462050906CD RXD: 3000 MTH: 000100010000 NAM: SYC
SYC
Camshaft & Crankshaft in sync (1 = in sync) (AlternTXD: 07E02209CD RXF: 0462050906CD RXD: 3001 MTH: 000100010000 NAM: SYC
TFT
Trans. Fluid Temp. TXD: 07E1221674 RXF: 046205160674 RXD: 3010 MTH:000100080000 NAM: TFT
TP1
Throttle Position 1 (Volts) TXD: 07E0220917 RXF: 046245090617 RXD: 3010 MTH: 0064040000000 NAM: TP1
TP2
Throttle Position 2 (Volts) TXD: 07E0220918 RXF: 046245090618 RXD: 3010 MTH: 0064040000000 NAM: TP2
TPA Throttle Position Actual (Degrees) TXD: 07E022093C RXF: 04624509063C RXD: 3010 MTH: 0064020000000 NAM: TPA
#36
9.6volts is the cut off the PCM resets at this point
Battery Float charge should be 12.6volts
I guess what Im saYing is anything less than 9.5v and there is no chance it will start your also going to start doing Electronics Damage at this Point to
#38
Good Deal When you start cranking on it just leave the charger Hooked up
A newer charger will shutoff when done chargeing so shouldnt cook the Batterys
IF it has a start Position on charger put on that when cranking but stick it on a slower charge if leaving it over night or whatever
#39
I used the "speedy charge" setting so it'd charge in a a few hours. My charger has a "Start" setting that I haven't used before. Next time I try to crank it I'll hook it up and use that as a boost.
I plan to get the 2nd battery charged, then enter the codes you provided (thanks again!) into the SGII. Once those codes are entered I'll hook the charger up to give that boost when starting and try to crank her over again.
After I try cranking it again I hope the SGII will pull some usable data that I can then post here. I should know more in a a couple hours.
#40
I have some numbers now, lets hope they mean something...
I wasn't sure exactly when to take the reading, so I took a few. In addition to the ICP & IPR, I also took the FMP (FICM Main Power) and FVP (FICM Vehicle Power) in case they would help.
Reading #1 (Before starting, KOEO)
ICP 3
IPR 14.4
FMP 47.5-48.5
FVP 11.5
Reading #2 (While cranking)
ICP 450-522 (it fluctuated, I think it was mostly rising)
IPR 77.6 steady
FMP 48 steady
FVP 10.5
Reading #3 (One minute after cranking stopped)
ICP 3 (slowly dropped after I stopped cranking and settled back on 3)
IPR 14.4
FMP 48
FVP 12
Is this good or bad?
Thanks,
Todd
ICP 3
IPR 14.4
FMP 47.5-48.5
FVP 11.5
IPR 77.6 steady
FMP 48 steady
FVP 10.5
IPR 14.4
FMP 48
FVP 12
Thanks,
Todd
#41
You have a LPO or High Press OIL Problem
Your ICP was right on the edge of starting and IPR% was maxed out so that means the HPO side of things was starved for oil
Its hard to telll But looks like you have the wrong OIL Filter CAP
Is CAP OEM??????????? Are you 110% shure on this
Post a Pic of OIL Filter CAP
#42
#43
yea the oil filter is origanal cause all the aftermarket ones are about an 1inch taller, icp is just a bit low and ipr is maxed out like like said before, there are a few things that caould cause this, low oil easiest to check have seen many trucks towed and died just like yours and oil was low, d plug orings are worn out and is missing part of the o ring, or the other thing is hpop is bad, i dont think the 04 has the stc fitting but i cant remember at this time, but if it does that could be another possibility.
if you want to your self check the d plugs its really easy, you just have to pull the valve covers off and there will be 2 allen head plugs in the rail the front is the d plug pull it out and inspect the o rings, but being a 04 you might have just the straight hpo rail instead of the later wavy but with the icp in the passenger valve cover i am going with wavy with the d plugs.
when you are cranking and and monitoring icp does it climb slowly to that pressure
#44
One of the first things I did was check the oil, while still stranded at the gas station. It registered about 2/3 the way (on the full side) between min and max levels on the dipstick.
Are the D plugs about the size of a finger, with the one at the back of the engine having holes in the side and the front one with no side holes? If so, I think I've seen these taken out in a video before. I'm not sure if my rail is wavy or straight, but for some reason I think I read where the wavy rail was introduced after my model year.
#45
