I may have "oopsed" my MAF
Thinking that I was doing a good thing this spring I gave the truck a new air filter and good cleaning. I noticed a bit of fine white powder on the intake going toward the MAF. I removed the MAF and noticed it also had the fine coating on it.
I went out and purchased some MAF cleaner and gave it a good spray and cleaned the exterior of the unit with a soft cloth.
Now my MPG is maybe 2-3 worse than it was in the fall before storage when on the highway. I have put a few hundred km on it since the cleaning and I would think the computer has relearned all it nees to..
Plugs were changed just before storage along with a fresh oil change.
What would the signs of a bad MAF be? Driveability seems ok, maybe a little low on power.
Yeah the battery was out of it for about 6 months.
I cleaned the maf and reinstalled and let it sit for a day or 2 before hooking up the battery to make sure all cleaner had evaporated.
I called the local dealer and they want over $300 for a new one.
Are the aftermarket ones any good? Any brands to stay with or avoid??
t repaces your oil pan drain plug with a spring loaded nylon ball valve with a little nipple on the end to attach a hose to.
To change the oil you depress the spring held lever and simply drain the oil into a jug rather than messing with a pan and then jug.
The only thing you would need a pan or bucket for would be the filter.
