Truck leans to one side
I have a F250 heavy duty that has a lift on it(was on before I purchased truck). The aftermarket shocks are bilstein, not sure which model. The truck leans to the right a bit and at first thought it was tire pressure but checked that and it wasnt it. Finally i noticed that the rod/shaft of the right front side shock was shorter than the left by a cpl inches when sitting still. I am sure that this is causing the lean. However my question is how do I adjust it? Is it a leak or seal issue etc. Also the shock is a resovior type shock. thanks in advance
That's the problem with my 77... just being a ½ broken spring out of the stack makes it lean horrible
