Australia Chapter Join Chapter , Leader: ChunderDownUnder
Custom Ford Patrol
Old 03-03-2013, 07:56 PM
Madriver911's Avatar
Madriver911
Madriver911 is offline
Custom Ford Patrol
Hi my name is Trevor and i'm building a one of a kind Nissan Patrol. Its a 1975 G60 medium wheel base (100") patrol that is under going a full rebirth. It will be housing a 1996 7.3l Powerstroke V8 mated to a zf6 and a atlas 4 speed.
Hope you guys like it
putting this
into this
TRev
Old 03-04-2013, 03:34 AM
Diesel Submariner's Avatar
Diesel Submariner
Diesel Submariner is offline
7.3 Pootrol
G'day Trev,
You might want to check out a fella on this forum trying to stuff a 7.3 into a Tojo in Sth Africa.
That era Pootrol had a serious issue with the Chassis buckling and breaking in two .
Finding the space and allowing for the weight of a 7.3 + a ZF would be an interesting exercise.
All I can say is good luck mate and keep a good running blow by blow thread on this as you will have an audience willing you on.
Cheers,
Reg
Old 03-04-2013, 03:48 AM
SSSimon's Avatar
SSSimon
SSSimon is offline
There was another thread somewhere where a US Navy guy stuffed the 7.3 into his International Scout. He solved the under-power issue but created a whole pile more (which be also solved).
Old 03-04-2013, 05:09 AM
ChunderDownUnder's Avatar
ChunderDownUnder
ChunderDownUnder is offline
Not bad for ya first post. Welcome to FTE bro.
Im with Reg on this one. A 500kg motor in the front of that. WOW.
Old 03-04-2013, 07:22 AM
Madriver911
Originally Posted by Diesel Submariner
G'day Trev,
Cheers,
Reg
Thanks guys for the feed back and I'll do a search for those projects.
I'll give you some more info about the project. The driveline will weigh 150kg more then the original but i'll be doubling the cubes, doubling the transmission gears and doubling the transfer case gears. The chassis rails are a box section and the seem very strong but i will be adding fish plates and other bracing especial over the coil seats.
I'll be trying to minimize the weight by running a dry sump system, chromoly tubing for the cage and roof rack, alloy wheels and any other thing i can save weight on.
I know I'll be expecting issues but with the knowledge of the mechanical fitters at work, the forums I'm on and the tools I've got, I should be able to solve every issue.
Here's some of the tools I own
Question:
How do these engines and computers go by running without a turbo?
Thanks
TRev
Old 03-04-2013, 04:19 PM
ChunderDownUnder
y no turbo ?
Old 03-06-2013, 07:58 AM
Madriver911
I would like to remove the turbo for a couple of reasons. One, I'm not a fan of turbos and I'm trying to build a very reliable vehicle for remote self sufficient traveling. Two, I'm running out of room in the engine bay. The engine will be very close
to the firewall so I don't have much room for the exhaust system. I'm also running out of height which is one of the reasons I'm going to run a dry sump systems and I'm also running out of grill space for cooling. Running engine radiator, transmission cooler, oil cooler, condenser and thermo fan, there Isn't much room for an inter cooler.
TRev
Old 03-06-2013, 07:20 PM
aussie_f350's Avatar
aussie_f350
aussie_f350 is offline
So will you still run electronic injection? Will make the tuning interesting, factory ECM or aftermarket?
Old 03-07-2013, 12:42 AM
ChunderDownUnder
Yes endeed Andy. I understand where you are coming from but running a turbo'd motor without one would make it pretty gutless. I not to sure how you would tune around that.
Trevor - you may be best to ask that question here m8
https://www.ford-trucks.com/forums/forum170/
fordman67
12-03-2020 03:31 PM
prime builders
02-19-2017 06:25 PM
Uzumati
2017+ Super Duty
20
10-26-2016 09:49 PM
CheeksMcDuke
51
07-07-2010 01:40 AM
k2vailkid
08-19-2007 11:05 AM
Quick Reply: Custom Ford Patrol
