93 f250
93 f250
I just bought a 93 f250 7.3l idi and it first smokes black smoke then a burst of white smoke..I did have to add anti freeze..Any Ideas??and when it first cranks up it cranks right up then dies unless i give it fuel.It does have an aftermarket exhaust on it.Any ideas on that problem?One injector return line seal is also leaking..Thanks ahead of time.
Pre-Power Stroke Diesel (7.3L IDI & 6.9L) - Ford Truck Enthusiasts Forums Here is a link to the page for your engine, maybe post your problem there.
However you need to fix the return line leak. Maybe get a return line kit and replace it all. Any leak will allow air intrusion and so fuel drain back, which shows up as engine wanting to stall shortly after starting.
slvrtngdvl71
02-14-2024 04:56 PM
1reddawg12r
15
09-26-2022 04:42 PM
