leveling kit for f150 question
I want to put new coil springs on my ford 1996 f150. I know that from the factory the trucks sat level. I have read that if the trucks have a/c and other options in them and you put new stock coils back in then the truck will sag in the front. I also that about puting 2" coils in the front. not sure what to do eny info or insight you have will help.
I'm going to assume your truck is 4wd, only because you haven't stated otherwise. You are incorrect in saying that the trucks are level from the factory. there is usually about a 2" difference from back to front. There are several ways to level these trucks. Some companies sell leveling kits, taller springs or a coil space, or you can buy springs for a 2wd F250 and use those to level it.
shamrock442
1999 to 2016 Super Duty
03-21-2007 09:51 PM
spencry25
07-17-2003 11:03 AM
