Flathead Not Worth The Bother, To Finicky?
Hi, I'm new on here and I wanted an honest opinion. I am going to build a 1949 Mercury M1 half ton pickup with modern steering and suspension but with an 8BA flathead engine and S-10 T-5 transmission and 8.8 rear Lincoln I.F.S. I've never owned a flathead vehicle and I love old school stuff but I talk to a lot of people who say they aren't worth it, don't bother, use a small block. They say flatheads are heavy, poor oiling, always have to adjust the valves, oil leakers, overheaters, low power, unreliable,weak bottom end, big $ to build up for more power with a limited increases without a blower. I think they are cool engines and would like to try one, what are your real world experienced opinions? Thanks in advance, Rob
DW
Hi, I am going to build a 1949 Mercury M1 half ton pickup with modern steering and suspension but with an 8BA flathead engine and S-10 T-5 transmission and 8.8 rear Lincoln I.F.S.they are cool engines and would like to try one, what are your real world experienced opinions? Thanks in advance, Rob
Sure they're neat engines. A local guy has two high tec, very nicely done roadsters, both running flatheads. And yes, he drives them. I think one is a six speed and the other is a five speed.
What are you going to do with your truck? Long freeway drives? Drag racing? Are you going to want A/C and P/S? I'd guess so from your choice for suspension. If so, go ahead with the SBF or SBC, leave the good flatheads for us stocker guys!
Seriously, your friends' advice has kernels of truth compared to modern engines -- wouldn't you expect in 60 years they'd make some improvements? A flathead that makes much more than 125 - 130 HP will cost as much as a 5.0 that makes 300, and then you have to figure out how to hook up accessories that it was never designed to have.
It just depends on whether you want a true classic or a street rod. A flathead in a truck with IFS/IRS doesn't make a lot of sense IMO.
They were rated when new at 100hp, and that was probably optimistic. You can also figure on a 20% hp loss through the rest of the drivetrain to the rear wheels. You're not going to win too many stop light drag races. With only 239 cubic inches and the compromised breathing they have, power potential is no doubt somewhat limited.
Reliability is going to be no different than anything else. People drove them daily and across the country for many, many years. If you take care of them and keep them in tune, they'll run forever. Ditto, and they won't overheat on you, either. But it will need a tune up and plug change long before the 100,000 mile mark like your new Lincoln.
The bottom end only has 3 main bearings instead of the more common 5 mains in a modern V8, so there's going to be some limitations on how much horsepower it can stand. But as long as you're not doing anything stupid to it, it's more than capable of keeping up with it's intended potential.
Yes, parts are going to be very expensive. It's not a SBC so don't expect to find a $99 rebuild kit at Auto Zone. Low demand = low production = low ROI = high costs.
I believe you are correct in that they are really cool and a part of our gearhead history. I'm looking forward to playing with my first one, as well. All that said, if I was building a heavily modified hot rod truck with all the modern conveniences of power everything, IFS/IRS, etc., I don't think I would stick with the old school engine. It just wouldn't be right.
Yah, you don't want one of those old things.....send it over to me, I'll put it to use! LOL!
They aren't for every one, but once you have one you will fall in love. Mine starts on the first turn, doesn't burn oil, doesn't over heat and really purrs like a kitten.(I probably just jinxed myself)
BUT. It took a lot of work and tinkering to get it to that point. Plus a lifetime of playing with these motors doesn't hurt.
I recently added a 5 speed to it which really makes it fun to drive. I drive my truck every day if possible.
Bottom line, it's just an engine......any engine can be good or bad.
on
...a lot of people who say they aren't worth it, don't bother, use a small block. They say flatheads are heavy, poor oiling, always have to adjust the valves, oil leakers, overheaters, low power, unreliable,weak bottom end, big $ to build up for more power with a limited increases without a blower. I think they are cool engines and would like to try one
The Hill Boys
71
06-27-2015 08:46 AM
F1Jayhawk
15
08-23-2011 11:11 PM
Railroader18
07-24-2011 05:32 PM
