2.0 to 2.3 swap
Old 05-21-2012, 01:35 AM
postmaster ford's Avatar
postmaster ford
postmaster ford is offline
2.0 to 2.3 swap
Ok guys so I just got this truck its a 1980 courier 2.0 with a 5 speed. I know I can make huge power out of a 2.3 "mini stock pinto" but how does this engine differ from the 2.0 Mazda engine I have? Specifically bell housing, tranny alignment bolt pattern, and motor mounts? Any help would be great thanks!!
Old 05-21-2012, 07:19 PM
critterf1's Avatar
critterf1
critterf1 is offline
EVERYTHING is going to be different because it's a true Mazda.
Old 05-21-2012, 07:29 PM
postmaster ford
Even the trans bolt pattern?
Old 05-22-2012, 10:03 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Rogue_Wulff is offline
The 2.0 is a Mazda engine, while the 2.3 is ford. Trans will not swap between the 2 engines.
The 2.3 was installed in some Courier's, but I don't know how involved it will be to do this type of swap. The radiator and driveshaft may work, or they may not. Pretty much everything else between them has to be changed.
Old 05-22-2012, 11:12 AM
postmaster ford
Ugh not what I wanted to hear! Of course I have the oddball !!!
Old 05-24-2012, 10:51 AM
Rogue_Wulff
The Courier was built by Mazda for Ford. The 2.0 is not the "oddball" engine, the 2.3 was.
Old 05-24-2012, 12:04 PM
postmaster ford
Ya I know but how come the oddballs are so plentiful?
Chewy1978
09-22-2015 01:17 PM
juchertf100
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
02-24-2015 12:05 PM
Scolesy8
04-10-2011 06:02 PM
computerbob56
03-15-2004 07:10 PM
moore1960
10-26-2002 10:32 AM
Quick Reply: 2.0 to 2.3 swap
