AIR CONDITIONER
Old 05-20-2012, 07:25 PM
BIG-DADDY-F350's Avatar
BIG-DADDY-F350
BIG-DADDY-F350 is offline
AIR CONDITIONER
My E99 air conditioner is acting up. At start up it will run some days, at other times it won't. When it wont work, I can leave it on high and within 5-20 minutes it will come on. Does this sound like a fualty switch or bad connection. How much of a chore is it to access behind dash? It will be getting hot soon and I need to get this cured. Any help will be appreciated.
Old 05-20-2012, 08:04 PM
bcaughhorn's Avatar
bcaughhorn
bcaughhorn is offline
Old 05-20-2012, 08:07 PM
bigb56's Avatar
bigb56
bigb56 is online now
A good place to start is to check the charge level. When the system is in it's failure mode you can TEMPORARILY jump the pressure switch on the accumulator and see if the compressor starts. If so, you are either low on refrigerant or the pressure switch is bad.
Old 05-20-2012, 08:09 PM
Smokiesman's Avatar
Smokiesman
Smokiesman is offline
You might want to put a pressure gauge on the system to see what you got for pressure!! Just might need some juice aka that gold they call freon nowdays!! Dang he beat to the punch!!!!
Smokie
Old 05-20-2012, 08:14 PM
youknowitdadio's Avatar
youknowitdadio
youknowitdadio is offline
Mine didn't work and they said it took like 4.5 liters? compared to 1.5 for most cars. Plus oil. Ran me about $240. Ouch
Old 05-20-2012, 09:35 PM
Poolguy601's Avatar
Poolguy601
Poolguy601 is offline
Does any one have the service procedure for replacing the compressor pulley bearing.
Old 05-20-2012, 09:59 PM
BIG-DADDY-F350
I should've said blower not running instead of air conditioner. I can feel cold air and not much circulation when I set it to A/C. When I switch to Max A/C I get no fan at all and no cold air at all. If I leave it on the max setting and keep driving, then it will randomly come on when it feels like it. Does this sound like a switch problem?
Old 05-20-2012, 10:11 PM
Smokiesman's Avatar
Smokiesman
Not sure about the Ford but if they have a blower reg I would bet on that!!
Smokie
Old 05-20-2012, 10:12 PM
Poolguy601's Avatar
Poolguy601
It sounds like a relay or resistor problem
Old 05-20-2012, 10:22 PM
big poppa's Avatar
big poppa
big poppa is offline
Not sure what fuse but I'd start finding the fuse for the fan blower motor first, it might be blown then checking the fan blower itself. I've experenced blowerless cold air in other vehicles and it was either a fuse or the blower, check those first.
Old 05-21-2012, 09:12 AM
BIG-DADDY-F350
This is good info. Thanks gents!
Old 05-21-2012, 11:48 PM
big poppa's Avatar
big poppa
Let us know what you find, always good to follow up with the cure..
Old 05-22-2012, 07:31 AM
bigb56's Avatar
bigb56
In light of the new information you provided I can tell you that the dashboard blower speed switch on the vans seems to be weak. I have a buddy who runs a couple of E series vans in his tile business and he has replaced the speed control switches more than once.
On edit I see you mean early 99 not e series. I am still betting on the blower switch.
Old 05-22-2012, 01:09 PM
BIG-DADDY-F350
I will be posting my finds on this when I figure it out. Thanks again Gent's!
EBbroncoII
1966 - 1977 Early Broncos
01-28-2013 07:59 PM
mtlease
03-19-2011 11:08 PM
HISGTO
10-30-2010 04:58 AM
cigarxtc
Oklahoma Chapter
05-14-2009 08:06 PM
TOOT
1997 - 2003 F150
06-06-2005 10:48 AM
Quick Reply: AIR CONDITIONER
