2010 Transmission ?
I assume you're talking about being able to drain the fluid for a full tranny fluid swap? If so, it seems like there is no way to get the fluid out without having a special machine. There are quite a few threads about this on the forum, doing a search will dig them up.
I too am dying to do my own fluid change, but have not yet found a way to do it easily.
A 2010 does not have a torque converter drain plug. A 2000 does. To change all of the fluid in the 2010 you MUST use a heated flush machine.
To change all the fluid in the 2000 you could use this:Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles. Or you could drain the pan and remove the torque converter drain plug and change almost as much.
on
Borgunit
17
09-07-2004 09:02 AM
Banjo5150
02-15-2004 02:43 AM
greg_23805
07-30-2003 06:31 AM
