R134a A/C fresh charge
Old 08-03-2012, 12:19 AM
eatont9999's Avatar
eatont9999
eatont9999 is offline
Originally Posted by vfelix702
So have you tried any of it? A refridgerant called "hot shot" is a replacement for r12 its not a drop in replacement so normal evac route is required.... if you can find it
I would go with DuraCool if I were to try a retail option. Right now, I am trying to figure out if I can get some off the shelf, cheap alternatives to work. Like I said, I have plenty of R12 if I want it. This is more of an exploratory project.
I added 16OZ of MSR IsoPro stove fuel. I hear it is 80% butane and 20% propane. What I put in is probably close to if not over an efficient charge to fill the evap. The problem is that the ratio is too far in favor of Butane. I did get nominal cooling with just the MSR but not near what I should be getting. I added several ounces of propane and started to get slightly cooler temps but the low and high side pressures started to climb. I need to bleed the system down to a reasonable ratio between high and low pressures, then bump it with some more propane and see if I hit a sweet spot. The ideal ratio is somewhere between 40-70% butane but it really depends on the OAT.
  #62
Old 01-07-2013, 09:17 AM
89ford73's Avatar
89ford73
89ford73 is offline
Need a restriction in your suction line to keep your low pressure up and highressure lower I used vicegrips to pinch the hose off lol but is very cold now. 32 at the vents, I have my thermometer set at 35,36 in a glass of ice water, hope this helps
  #63
Old 01-07-2013, 09:24 AM
89ford73's Avatar
89ford73
89ford73 is offline
Your low side should be 60-70 psi. Use the smallest oriface possible. The variable one doesnt work as well with propane. I had to figure out the hard way. What you need is restriction in the suction line to raise your low side pressure and lower your high side pressure. TRUST ME
  #64
Old 01-07-2013, 09:38 AM
89ford73's Avatar
89ford73
89ford73 is offline
Does your truck have valves behind the compressor? You can close off the suction valve 3/4 or so and that will do the trick
  #65
Old 01-18-2013, 04:50 PM
eatont9999's Avatar
eatont9999
I'll get back to this thread in the summer. Right now it is too cold to get readings from the A/C.
Liemavick
08-29-2015 12:37 PM
TX92F150
07-11-2012 05:31 PM
Chris 97 F150
1997 - 2003 F150
09-02-2010 02:35 PM
TigerDan
06-03-2004 10:25 PM
Colo_Steve
05-28-2004 01:18 PM
Quick Reply: R134a A/C fresh charge
