Gauges
Fine.... I'l just keep hanging them with zip-ties and brackets all over the dash. It's just that I already have some that work fine and hate to spend the $ for nos or reproduction. I really needed an accurate temp gauge with numbers as I work out a cooling system for my project fridge. They just might fit through the original holes in the back panel that holds the speedometer. I held one up behind the finish face plate and you can read them through the original holes. It's not like I haven't already butchered most of the truck already. What's one more piece?
I think the econoline gauge cluster has small gauges where the idiot lights are on a fridge gauge cluster. I have definitly one across pictures of gauge panels from big trucks like f750 having the same layout through the sixities and seventies.
The coolest ones have a tachometer and a vacuum gauge.
Here is an adapter panel on eBay ... not sure if anyone has experience with this. I am contempating the Dakota Dig gauges, but this is a solid backup.
Thanks, I-K At first I didn't see the link to the 84.00 option. I did however run down to the shop and did a test fit on a random gauge in the original mounting hole. Dead perfect slide in fit at 2 1/16" dia. The temp gauge will be where I have the OP gauge in the pic. The OP gauge is in a bit cockeyed so it doesn't look centered. I will make up some short tubes to hold them the correct distance back from the glass. Maybe some 2" pvc pipe, reamed out with a drill mounted drum sander....... Even the purists might agree the the black face on the right looks better than the faded out, non working gauge on the left. 'Darkness, darkness, be my blanket.' Jesse Colin Young
Got two in and working. Found that 2" abs plumbing vent pipe is about 2 1/16th ID and was a great collar for the gauges, cut with a chopsaw into 5/8" tall rings. This set them off the glass to factory specs. I found the gauges differ somewhat in dia so had to use a die grinder just a bit to pass one through the stock dash hole. It wouldn't affect remounting stock gauges though. The camera lens distorts the perspective, but the gauges are perfectly centered and you can read the numbers from the drivers seat. This was really easy, once I did the figuring. I bi-passed the voltage limiter for the stock gauges, as the aftermarket ones use 12 volts. One lead on the limiter is male, the other female, so I just unplugged them from the device and plugged the two leads into each other. Both my original fuel and temp gauges were shot, as testing from the ford shop manual proved, but I later found my tank sender float had sunk as well. The photo shows why, and I found a temporary replacement until I order the 14.00 float from Sacremento Vintage Ford.
I found this on Ebay today and thought it went well with this thread.
Ford : F-100 Ford : F-100 | eBay
