Installing New shocks
At 48k miles I am replacing shocks on all four corners. Got a new set of rancho 9000xls and going to install this weekend. It seems I am feeling every crack and bumps going down the road. I used to run at 70psi and now down to 60 and feel the same.
Any advise?? Any special tools or large size tools needed?? I think my largest wrench is 17 mm or equivalent in sae size. I do have a crescent wrench as well.
It looks easy enough, top and bottom bolts.
Going on 39K here. 'Night and Day' meaning a softer ride? My wife hates riding in the truck these days. She says all the bumping and shaking makes her ill
Ok, did the deal in about 1 1/2 hrs. Anyone who reads this post. If you have stock shocks change those things. It was the best $225 I have spent on this truck yet. I found a $325 price from one source in FL but I live in FL so I did not want to pay taxes. Summit racing matched their price and there is a $100 rebate for ranchos 9000xl
I did the rears without even jacking or removing tires. The front I removed tires and it was a pain in the butt with the top nut. I used a 7/8 wrench it worked but kind of big. I think it is metric, imagine that. It was a pain without a non ratcheting wrench. I have a basic air tools set so it was easy getting bolts and nuts off.
Night and day. My truck felt like I had NO shocks.
My 2006 fx4 250 had ranchos on them. From what I understand those are the cheapest made ranchos ford bought to put on the trucks to make it look like it was off road vehicle. Don't judge the shocks by them. These aftermarket ranchos are way different
Trust me you will be asking yourself why you didn't do it sooner! The bumps are definitely a lot smoother.
shock testing
I too went to the 9000xls shocks but at 10 or 20k just because i felt they would be better. They are indeed very AWESOME. i also tried Eldebrock and something else but can't remember but the high end Ranchos felt the best to me on my truck. They're good right out of the box but get better after 2k or so. I will definitely do the same again. By the way the other two are good to but the 9000's definitely felt the best to me.
In fact, just found this:
Comparing a shock that we make to Ford's specs (that retails for $40ish) to a shock that retails for over $100.00 dollars. The $100 shock should be better.
Hence many people like the 9000XL and the ability to set their shock to their desired ride. Now reaching under a truck and twisting a **** once in a while, pretty simple, especially if you are looking over your truck once in a while.
