Hub, rotor spindle swap????????
The D50 should have larger disks & dual-piston calipers that wont' fit inside the 15" rims that the D44 used. The D50 stub shafts are larger, so the spindles are, too, and they probably mount with more studs than the D44. The hubs are DEFINITELY different, because they use a MUCH larger hub lock.
I guess I didnt explain fully, sorry. The Dana 44 is a 3/4 ton from a 78 F250 it already is 8 lug but its the small hub version. It has dual piston calipers already on it. The reason I want to swap is because everything is shot on the 78 and the 93 everything is new.
Sean Balboni
23
04-09-2013 08:02 PM
dougbrown
01-17-2012 09:28 PM
oldhalftons
05-27-2004 06:17 AM
