10.5 Sterling Maintenance questions.
Old 05-23-2012, 12:49 AM
louisianajones's Avatar
louisianajones
louisianajones is offline
Impish,
Assuming you will be notified by e-mail I just wanted to thank you again for the help. I finished installing the rear end this evening and everything is working great.
The only problem I had to work through was the brake/vent block on the rear end I purchased. It had a different fitting on the hose going up to the brake supply line in the frame. It was approx. .011 smaller than the one from the original rear end. I feel sure one of them was Metric. I removed the one from the original housing and put it on the new one, all the other fittings were the same.
So, thanks again!
Have a great week, Mike
TobaccoBarn460
12-12-2015 10:10 AM
JHoffman93
11-11-2013 07:14 PM
redman84
09-07-2010 10:03 AM
redbug
04-30-2009 10:56 AM
eagleridge5
1999 to 2016 Super Duty
01-07-2008 11:41 AM
Quick Reply: 10.5 Sterling Maintenance questions.
