rear gear oil type question
Hey Folks,
one other issue popped up this weekend;
I finally got to check the 51's rear gear's oil level, it's low and from the looks of it black as tar!
I only had a 'tad' bit of GL3/4/5 Napa 85wt oil left from topping the transmission off, so I put it in.
What type of gear oil/weight should I be putting in the Rear gear carrier?
I remember the 66 mustang took a hypoid 85/90wt and was kinda thinking the trucks probably the same.
Would more of the napa GL 3/4/5 [80-85wt] oil be fine?
Just curious, figured I'd better check before I dump it & change it. no need to do it twice!
Thanks!
T
Thanks!
T
can0fspam
08-16-2018 02:30 PM
unibody62
12-10-2017 06:48 AM
BigBlocker0248
02-20-2016 09:35 PM
sawyersvintage
08-12-2011 07:19 PM
