Alternator / System Questions
im trying to calculate a more accurate amp draw for my lights i will be installing soon. Im currently on travel so i cant go measure system voltage myself. the lights are advertised at 100watts, which at 12 volts is about 8.3amps which is worst case scenario, as the system should not be operating at 12volts, rather more like 14ish... just curious what people are actually seeing tho. if it is at 14 that would be great as 100watts divided by 14 volts would mean the lights are actually only drawing 7.1amps which would leave a comfortable margin for me to put all three lights on one 25amp upfitter/relay
also, lets say worst case scenario, im at 12 volts(highly unlikely id say) and the lights are at 8.3 amps... which puts the total current right at 24.9 amps (call it 25), would you be comfortable maxing out a circuit like that or would you think Ford put some safety margins on the power budget. (i dont know what its fused at yet)
Well, you'll love my solution. I just threw a 30amp fuse where the 25 goes so my air compressor won't burn the fuse if it gets worked hard.
Yes, I know, don't do it, I'm not saying its right, but my system has been running every day for almost 2 years now.
I will add, the air compressor also has an in line fuse that has burned twice. It always goes before the up fitter fuse goes. And the up fitter fuse has never blown.
