Trans cooler I think
Old 05-13-2012, 12:06 AM
k_conner's Avatar
k_conner
k_conner is offline
So I have a leak that I think is from my trans cooler. I have a smaller radiator (about the size of a large brick) in front of my main one that has 2 hoses coming off it. The one that is leaking goes into the bottom of the main radiator (I think) and the other turns into a metal hose and goes somewhere that I haven't traced yet. The fluid looks like ATF but I can't tell. What does everyone think?
Old 05-13-2012, 05:18 AM
427 fordman's Avatar
427 fordman
427 fordman is online now
That large brick is your trans cooler. The metal line runs back to the trans. Sounds like you just need to change the rubber hose you see leaking.
Old 05-13-2012, 01:48 PM
fordman67's Avatar
fordman67
fordman67 is offline
I have seen lots that the clamps just dont hold well enough to seal.add a second clamp even sometimes.
Old 05-13-2012, 10:10 PM
k_conner's Avatar
k_conner
k_conner is offline
Thanks guys. I plan on changing it this next weekend. When I disconnect the rubber hose from the trans cooler at the large main radiator how much fluid can I anticipate coming out?
Old 05-13-2012, 10:48 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
Not a whole lot. Get rid of that little cooler and get a tru-cool.
Old 05-14-2012, 02:25 AM
fordman67's Avatar
fordman67
So im not the only one to look at that puny thing and want to put a REAL cooler in place of that joke ford installed?
Old 05-14-2012, 05:28 AM
427 fordman
No you are not. Got a trucool in mine.
Old 05-14-2012, 08:12 AM
fordman67's Avatar
fordman67
I have a very large add on cooler i had left over from another project.i am a going to swap it out.
Old 05-14-2012, 08:45 AM
oldbird1965
I have a hayden and a tru-cool. Some use the stock cooler for a ps cooler.
Old 05-14-2012, 10:39 AM
fordman67's Avatar
fordman67
Yet another fab idea! And a good excuse to flush that system
Old 05-14-2012, 12:06 PM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Wink
One more here in my truck: Trucool MAX.
kyleag89
06-26-2017 08:21 AM
lud04X
08-15-2016 09:21 AM
SoCalAngler
09-08-2014 11:26 PM
wastingas
1997-2006 Expedition & Navigator
11-25-2012 04:24 PM
Quick Reply: Trans cooler I think
