Go Back   Ford Truck Enthusiasts Forums > Marketplace > Vehicles for Sale
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Vehicles for Sale All vehicles (Ford Truck or otherwise) for sale here
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Location (State):
Parts Search
Keyword:
Category:
Price:
Private or Vendor Listing:
Location (State):
Item Condition:
  #1 (permalink)
Old 05-09-2012, 11:19 AM
davelength's Avatar
davelength davelength is offline
Garage is empty, add now
davelength is starting off with a positive reputation.
1994 Ford E350 Quigley 4x4 van
Year: 1994
Make: Ford
Model: E-Series Van
Price: $7000
Mileage: 85000
Color: Blue
Private or Dealer Listing: Private Listing
Location (State): NC
Transmission: Automatic
Drivetrain: 4WD & AWD
Color: Blue
Engine: 351
Located in Raleigh, NC.
Cargo van with comfy chairs, power windows, power locks
351 with Crane cam and mild headwork
Pacesetter long tube headers, high flow cat and muffler, 3" mandrel-bent exhaust. Nice sound but not loud
Rebuilt E4OD transmission with TransGo shift kit, new filter and fluid, and 4R100 oil pan (drain plug)
Dana 60 full-float rear axle with limited slip and 4.10 gears
Dana 44 front axle with auto hubs and 4.10 gears
Borg-Warner 1356 hi/low transfer case
BF Goodrich 265/75-16 A/T tires and matching spare
Hitch, Prodigy brake controller and 7-pin plug
Alarm with keyless entry and immobilizer
Sony CD player with iPod connector and aux input
Halon fire extinguisher
Streamlight Stinger flashlight and charger
Air compressor, 5-gallon air tank and retractable hose reel
Battery tender
Cold A/C and excellent heater.
Some extras:
Tool bin with jacks, recovery straps, and other MacGyver goodies
Decent junkyard middle seat (no mounting hardware)
Aluminum motorcycle ramp
Wheel chock and several sets of tie-downs
Good used front left fender (existing one has a small tear/dent)
Known issues:
Minor body damage, paint is fading, clear coat coming off in a few places
Airbag light is on. Code says it is the little blue box under the dash. I never bothered to research it further, since I am not sure I want an 18 year old airbag going off anyway.
Passenger window does not go up with driver's door switch. Works fine (up and down) with the passenger door switch. I checked the obvious things, and may look some more if I have time.
Click the image to open in full size.
History:
The van is titled as an E150, as that is what it started out as. I happened across an E350 Quigley with a damaged body and could not pass up the opportunity to build the 4x4 that I had always wished I had. I ended up rebuilding the E350 chassis and then putting the blue body from my E150 on the Quigley chassis.
While I had it apart, I refreshed the engine, which only had about 70K original miles on it. Installed the new cam and lifters, did the head work, had the custom exhaust work done (including ceramic coating the headers and Y-pipes). I used the E4OD transmission out of my E150 since it had just been rebuilt a few thousand miles before. I added the shift kit, installed the updated pan and changed the filter and fluid. Replaced all the brake components (pads, rotors, calipers, shoes, drums and wheel cylinders) and recently replaced the shocks. I also replaced as much as I could when I had it all apart (timing chain, water pump, fuel injectors, valve guide seals, motor mounts, radiator, hoses, u-joints, etc).
The van is in great mechanical condition, I would not hesitate to hop in it tomorrow and drive across the country.
  #2 (permalink)
Old 06-26-2012, 05:38 PM
thomasaallen thomasaallen is offline
thomasaallen is starting off with a positive reputation.
i'm interested in your ford quigley. my name is thomas, i'm in tennessee outside knoxville. i am serious about buying, i have cash, but would like to talk before making a long drive. my number is 865-208-0905. please let me know if it has been sold. thank you.
  #3 (permalink)
Old 06-26-2012, 10:20 PM
davelength's Avatar
Hey Thomas,
Unfortunately the van was just sold this morning. I am working on removing all the ads I had for it.
Thanks,
Dave
  #4 (permalink)
Old 06-27-2012, 07:00 AM
atikovi atikovi is offline
atikovi is starting off with a positive reputation.
Somebody got a deal.
Tags
1994, 1996, 350, 4x4, 94, cost, e350, ford, modify, nc, quigley, quigly, rebuild, sale, suspension, trucks, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
