Motorcraft 2150 carb Vent?
I am rebuilding my Motorcraft 2150 carb. It is out of my 66 F-100 that the PO put a 390 FE motor in from a 74ish F-250. I assume this carb comes from the same vehicle, but who knows about any of that . . . tag on the carb identifies it as a 2150.
My vehicle has a manual choke so I assume the automatic choke was removed.
Anyhow my question is this: There was a tube hooked up to the back of the carb. I think it's hooked up to a vent. The other end of the tube was not hooked up to anything. Just dangling there. Is this the way it should be?
A photo is attached illustrating the tube I am referring to:
Thanks.
Thanks.
SOLVED
Found the answer here:
2150 fuel bowl vent tube [Archive] - FSB Forums
Apparently the line originally went to a charcoal canister, but should be left open if no can exists.
If the vent is plugged then that will cause problems explained in the above link.
NumberDummy - if you can confirm that this carb came from a 74 or 75 that would be cool to know. The PO said 1972, but didn't seem to confident in that answer. Thanks.
mOROTBREATH
06-29-2019 08:30 PM
Justpool
12-07-2017 11:58 PM
charles jones
03-12-2006 12:36 AM
