carb set up
Old May 17, 2005 | 08:51 AM
PRyan1983's Avatar
PRyan1983
carb set up
I'm putting a new carb on my 72 f100 with a 360. There is a vacuum port on the passenger side top corner of the card kinda angled down a little. Where does it go. It wasn't hooked up on the original carb. Also, my truck dosen't have the choke heat tube. Where can I get one or how can I make one? Thanks.
Old May 17, 2005 | 09:18 AM
bsour's Avatar
bsour
What brand and model is the new carb?
You could put a manual choke on it.
Old May 17, 2005 | 09:34 AM
PRyan1983's Avatar
PRyan1983
I went to NAPA and bought a direct replacement, just like the original. I think the vacuum port is called a "choke clean air tube". Where should it go? Thanks.
Old May 17, 2005 | 11:11 AM
qman's Avatar
qman
I don't think it's much of a vacuum port. I think it's more like a vent. It should have some hose coming off it that connects to a metal tube that connected to the exhaust manifold. Kinda like the other metal line that feeds warm air to the choke. I hit a bump and my metal tube fell off so I just stuffed a bolt into the hose. All I could figure was that it fed warm air into the fuel bowl of the carb.
Old May 17, 2005 | 12:07 PM
4Cammer72's Avatar
4Cammer72
that should go to the air cleaner. the vented fumes are sent back to the carb drawn in by the vacume to be burned
crazed87bronco
Feb 7, 2012 08:08 AM
79outlawf150
Jun 1, 2010 07:42 PM
1964_mezajd
Apr 13, 2007 02:22 PM
Lobo 2
Mar 2, 2005 05:44 AM
deondanno
Jul 14, 2002 03:40 PM
