Death Wobble
Old 05-04-2012, 10:02 AM
52 Merc's Avatar
52 Merc
52 Merc is online now
Received 2,451 Likes on 1,398 Posts
Originally Posted by petemcl
Also note that he says that it gets better with the tire pressure lowered to 22 psi.
Actually, he said "I have noticed that lower tire pressure increases the wobble occurring. Currently running bias ply @ 22psi." To me, that sounds like if he ran the proper and recommended air pressure for his tires, it might just cure the problem, all by itself. Still, I'd like to see his actual current alignment spec printout. Whenever one starts altering the ride height and attitude of the stance, that changes the whole dynamic of the suspension geometry. After that, all bets are off.
Old 05-04-2012, 01:00 PM
petemcl's Avatar
petemcl
petemcl is offline
Still Learnin'
Sorry, can't read and type at the same time.
Yes, you are correct about the printout but the problem is that it does it on compression and/or rebound so the springs are not in the static position.
Old 05-08-2012, 01:56 PM
Schmitty's Avatar
Schmitty
Schmitty is offline
Thanks for all the replies. Haven't had a chance to get under her and recheck tow and exact caster yet. Hopefully this week. I did bump the tire pressure up to 30 and still got the wobble the other day possibly even more violent than at 22psi. The tires are rated to a max psi of 32 and boy does that increased pressure make for a stiff ride...think I might go back to 22...
Old 05-08-2012, 04:28 PM
AXracer's Avatar
AXracer
AXracer is offline
Seldom if ever should a tire be run near/at the max pressure stamped on the tire, that is the maximum safe hot pressure that should NOT be exceeded. Tire pressure can easily increase 5-6# from cold to hot. Check the manufacturer's specs for your tire size for the normal inflation pressure.
Old 05-08-2012, 04:35 PM
rollincoal90's Avatar
rollincoal90
rollincoal90 is offline
bubbel in the tire
Old 05-08-2012, 04:59 PM
petemcl's Avatar
petemcl
petemcl is offline
Still Learnin'
Originally Posted by rollincoal90
bubbel in the tire
dubbel bubbel troubel
22 is way too low for highway driving. If your ride is too harsh then you are going to have to deal with shock valving and spring rates.
Old 05-08-2012, 07:59 PM
oldmerc's Avatar
oldmerc
oldmerc is offline
oldmerc
If everything in the suspension is tight and all steering componants are in good shape .
I would have an alignment done at a good shop ,if not allready . My choice would be to switch to radial tires . I know this has all been hit on but I like the sound of my own typing .
bballcrf
13
05-24-2021 04:55 PM
rungunner
07-22-2015 10:16 PM
F-250 WARHORSE
02-19-2012 01:34 PM
bobbytnm
54
04-25-2006 04:26 PM
taylor0987
01-10-2005 10:25 AM
Quick Reply: Death Wobble
