You may have a problem with the air injection if you have the tubes running into the rear of the manifolds. You can get some bungs welded in if you have that type of air injection
I know my 96 had that type. I ended up removing the air injection and using flowtech ceramic coated. Worst fit ever. Hung right at the trans xmember and to close to the driveshaft.
