A/C compressor Died - Ford Techs come in here
Old 05-21-2012, 05:53 PM
96_F250_Deezal's Avatar
96_F250_Deezal
96_F250_Deezal is offline
$335 for compressor, dryer, orifice tube and belt. $242 for new fan stator.
Old 08-04-2015, 02:30 AM
mario1987's Avatar
mario1987
mario1987 is offline
here is a question, i want to put auxiliary air on my truck, i dont have a/c and was wondering if i buy a a/c compressor can it be plumbed to fill a tank for my air bag helpers?
Old 08-04-2015, 02:51 AM
87crewdually's Avatar
87crewdually
87crewdually is offline
You should start your own thread for "on board air " and do a search.
You can use an a/c compressor but to make it last you need to run an oil separator with a drain plumbed back in to the suction side of the compressor. The reason being is to recharge the compressor with some PAG oil or the compressor won't live long. I have an elaborate system on my rock crawler samurai that bumps up the throttle and turns off @ 150psi. plumbed into a 6 gallon tank using a stock A/C compressor and pressure switch. You can find plenty of info and parts here: ::Kilby Enterprises::
Old 08-04-2015, 07:09 AM
mario1987's Avatar
mario1987
Appreciate the info I just didn't know where to start as far as if it could be done and if it weighs out the cost I'll just get an onboard air compressor system kit
Old 08-04-2015, 07:25 AM
87crewdually
For just air bags it's probably to much work and money. I run air ratchet and air impact guns off of my system for trail repairs.
Sounds like you'd be fine with a Viair compressor. http://www.amazon.com/gp/aw/d/B000X9...-zL&ref=plSrch
kountzecobra
2009 - 2014 F150
03-13-2019 06:27 AM
Ford12v
05-21-2014 07:49 AM
cricketmowing
02-06-2013 08:56 PM
BadAssFord
1997 - 2003 F150
12-27-2007 12:12 PM
agelder
Aerostar
08-07-2003 01:00 PM
Quick Reply: A/C compressor Died - Ford Techs come in here
