48 f1 front fender height
Hi I need your help.my front fenders measure different heights 27 1/4. Drivers side 29 passenger side fiberglass fenders measured from level ground to opening of fender.spring height is the same both sides the truck sits low in front to drivers side It has always been this way changed cab mounts came up a little.noticed suspension arm drivers side needs replacing.Is there any way to adjust front end to level fender height in front any input would be great thanks
There's at least a dozen different things that could cause a difference in fender height. Before we can tell you how to fix it, we need to isolate the problem so we know what we're dealing with. Where exactly are you taking your measurement from? Are these the fenders that have always been on the truck since you've had it? Is the bumper level? Is the frame level? How's the gap between the top of the frame rails and the lower grille valance? Does the radiator stand up perfectly straight, or is it crooked, even a little bit? How's the springs? Are the arches the same? How about the shackle angles? Bushings? These are all places to start looking for problems.
Thanks tires are the same air pressure 32 all around fenders came with truck always leaned to drivers side.valance is 1/8 inch difference on passenger side.springs have been rearched and checked measured with straight edge level floor to top of spring 1/4 difference higher passenger side.Sam's amount of springs both sides.bottom of fender to running board 1/8 difference on passenger side.I measured the door handle heights exactly 1 inch lower on drivers side.front bumper 1/8 high on passenger side also I noticed wheel well openings are off against tire. Measured with tires straight passenger side back of wheelwell 1and 1/2 wide drivers side 2 and 3/4 wide also I measured axle 1 inch difference on drivers side to backing plates the truck steers fine why would the axle not be centered.Measured truck on ground to center of front wheels same measurements both sides its when I measure above the center of wheels to center of fendar openings that I get a 1 inch difference.I have noticed the passenger side tires on the inside when turned all the way to the right rubs on the inside sheetmetal.I measured this side from backing plate in and it sticks out 1 inch more than drivers side.Thanks for your advice and hope we can get to the bottom of this.Have a great day!
I'm going to go out on a limb here and say the problem is not in your fenders. It's in your frame and/or suspension. Once you figure out exactly where the problem is, that'll fix the leaning issue. Keep measuring. You're on the right track. If necessary, find a good alignment shop or big truck frame shop and have them help you. It could just be a matter of adjusting your frame for straightness. It only sounds scary, if it's necessary, it's not a big deal at all. Having a twist or diamond in the frame is quite common for the design. With the right equipment, it's an easy fix.
I would suggest you take out some Jack Stands (on all 4 corners at the same time) and use them to support the frame. As you measure you have issolated the suspension and tires out of the problem. If everything is within a 1/2" (side to side) I would move the front jack stands under the front axle measure again note your measurements (including to the frame rails). While you have it like this check your king pins (a bad one can give you some drop and everything adds up). Move the front stands back under the frame and move the rear under the rear axle. start measuring again. This should tell you where you have issues to look at...
Thanks for all your input the jackstand theory sounds great.This is why I posted this you guys are great.I had a feeling that the axle was off maybe the truck got hit in the 50's and has been compensated ever since.The axle is an issue there are no adjustments to slide from side to side u bolts are fine no movements anywhere but it is moved over 1 in.out on passenger side I don't think ford offset these axles maybe someone knows if they did.I willtry everything you guys said with measurements and then find a good truck shop but why doesn't the truck pull to one side I let go of the wheel it steers straight,, can the axle be reshifted back to center? Thank you again for all of your suggestions have a great day
Thanks makes sense how would I know what side is the right height to start measurements.?The drivers side looks normal but passenger side looks raised.The drivers side cab suspension arm bushings are shot part of rear of cab 1/2 in lower than passenger Side I have new arms coming will install Saturday but this really should not affect the.fender issue on passenger side because cab is seperate from fenders? Thanks for your reply, are there stock frame measurements to go by and compare numbers? Have a great day
Chances are neither side is correct, so look for things that are different from side to side, and for things that just don't seem right. The axles were not offset. The track should be straight and true. Springs should be the same. The frame should be straight and symmetrical. If you take cross measurements from various points, the numbers should be the same. Any variance more than 1/8-1/4" indicates a problem.
While it's not a bad thing to replace cab mounts, especially if they are excessively worn, that's not going to be the root of your problem, as you've described. Don't expect miracles there. Your problem is in your frame and/or suspension. It's like a house with a bad foundation. If the doors stick and the windows won't open, it's not because the roof is saggy. Once you fully take a grasp on that, the rest will fall into place and it'll be easier for you to see the true situation.
Thanks the reason I am changing mounts is to have a starting point to work out from.I understand this is not the issue, but having the cab taken care of fixes other issues. The axle is a real problem being offset and the frame the same type of issue with fender being off, thanks for your input, Steve
lm987
10-08-2014 11:14 AM
train2
13
05-11-2012 12:48 PM
retro48/52
25
01-09-2009 09:54 AM
halfdone
26
06-12-2006 09:08 PM
