Go Back   Ford Truck Enthusiasts Forums > Misc. > Towing, Trailers & 5th Wheels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Towing, Trailers & 5th Wheels SPONSORED BY:
  #1 (permalink)
Old 04-30-2012, 11:33 AM
jdadamsjr's Avatar
jdadamsjr jdadamsjr is offline
Garage is empty, add now
jdadamsjr has much to be proud ofjdadamsjr has much to be proud ofjdadamsjr has much to be proud ofjdadamsjr has much to be proud ofjdadamsjr has much to be proud ofjdadamsjr has much to be proud ofjdadamsjr has much to be proud ofjdadamsjr has much to be proud ofjdadamsjr has much to be proud ofjdadamsjr has much to be proud of
Bug KILLER !!!!!!!!!!!!
Ok, making the trip at night down to College Station before heading thru Houston to lunch with Torreador Diesel and on to Lafayette, La made for a much shorter drive the next day, BUT
A gazilion bugs are now on the front of our new truck and 5th wheel....
The truck went through the car wash and so it's good,
but what do I do for the 5th wheel ?
I am past when I want to do it myself but will if I have to
Sooooo...do I:
Pay the highway robbery to have it washed at the dealer?
find a truck wash and see how much they charge ?
get some steel wool and sandpaper ?!?
or simple green, or ?~?
open to suggestions as I tried my little wash brush and it didn't dent the bugs...
then once cleaned, how do I make it easier the next time ?
__________________
13 F-350 Platinum 6.7 CC SB Tuxedo Black Metallic 11.5k gvwr,
13 Explorer Sport 3.5 Twin Turbo 365 hp Ecoboost Tuxedo Black Metallic.
12 MVP Destiny 355RE 5th wheel
gone-12 F-250 6.7 CC SB Sterling Grey Metallic Lariat w/ Ultimate Pkg. MBRP filter back Exhaust, Airlift air bags.gone-05 Ex 4x4 6L,even goner-2002 4x2 7.3L Ex Limited
  #2 (permalink)
Old 04-30-2012, 12:30 PM
BPofMD's Avatar
BPofMD BPofMD is offline
Old-Timer
2005 Ford F-250
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
Triple wax it!
__________________
BPofMD - Bud - USN-Actively Retired
Maryland Chapter Plankowner
2005 F250 PSD 4X4 LB Crew-cab Arizona Beige / Blue Spring / Gauges / Coolant Filter / SG-II / Peragon Bed Cover/ P/S Filter/ MAG-HYTEC differential cover/
2007 Arctic Fox 30' Fifth Wheel -2012 VW Passat SE TDI (An ALL-DIESEL family)
Join the Maryland Chapter click HERE
  #3 (permalink)
Old 04-30-2012, 01:15 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
power washer and stay away from the windows. Lower pressure nozzles.
__________________
http://www.ford-trucks.com/forums/pi...ctureid=114550
Scott-2008 F250 PSD Crew Cab 4x4, 12K GVWR,
Cooper Discovery STT LT275/70R18's
Banks Ram Air & 6-Gun, Ravelco Alarm System, Frontier Extreme FT. Bumper
2013 40' 4-slider stoneridge 5th wheel coming in at 15,400
http://www.ford-trucks.com/guidelines.html
  #4 (permalink)
Old 04-30-2012, 01:54 PM
jdadamsjr's Avatar
Guess best advice is not drive at night
I could SEE the butterflies, etc, dive bombing us !!!
Hmmm, think there is a high coin operated car wash close...
or should I just buy a power washer ?
Would a 1500 psi be the right size or ????
What about the vinyl decals - assume be careful with them
__________________
  #5 (permalink)
Old 04-30-2012, 02:09 PM
senix's Avatar
I have power washed mine a few times. mine is 2600 psi with the max nozzle. So I guess with my other nozzle it is about 1500 psi.
I have not had any problems.
I have a soap setting to spray that on the 5er then I have a long handle soft brush as well I can stand there and run it up and down on the really hard spots then spray.
Has worked well on those 2-3K bug runs.
__________________
  #6 (permalink)
Old 04-30-2012, 05:22 PM
RV_Tech's Avatar
RV_Tech RV_Tech is offline
RV_Tech is a splendid one to beholdRV_Tech is a splendid one to beholdRV_Tech is a splendid one to beholdRV_Tech is a splendid one to beholdRV_Tech is a splendid one to beholdRV_Tech is a splendid one to behold
Just wet the dryer sheets you use in your clothes dryer and wipe em over the front when you wash it and the bugs will come right off. Works on cars, trucks, anything, even when the power washer doesn't!
Steve
__________________
RVDA/RVIA Master Certified RV Technician
You think you're confused?
2002 F350 Dually, Rhino Liner, Edge Evolution (running in stock mode), 4" exhaust, 6.0 cooler
2010 F150 super cab, box stock, bed slide, ARE bed cover
  #7 (permalink)
Old 04-30-2012, 06:34 PM
BPofMD's Avatar
Old-Timer
2005 Ford F-250
Neat hint!!!! Thanks Steve!
__________________
  #8 (permalink)
Old 04-30-2012, 09:12 PM
jdadamsjr's Avatar
Atta Boy !!!
Now I just need a 20 foot by 20 foot dryer sheet and I got it made
Will give it a try !
and had heard that a long time ago, but forgot about it !!!
__________________
  #9 (permalink)
Old 05-01-2012, 07:13 AM
RV_Tech's Avatar
Quote:
Originally Posted by jdadamsjr View Post
Atta Boy !!!
So you don't have a dryer in that little fiver you are towing? Just put it in the bed of your truck!
Steve
__________________
  #10 (permalink)
Old 05-01-2012, 07:56 AM
jdadamsjr's Avatar
No washer dryer by choice and good thing since certainly you understand that it turns out that the washer/Dryer closet is the only space left for MY hanging clothes
Thanks
__________________
  #11 (permalink)
Old 05-13-2012, 05:10 PM
scraprat's Avatar
scraprat scraprat is offline
2012 Ford F-250
My Garage
scraprat has a great reputation on FTE.scraprat has a great reputation on FTE.scraprat has a great reputation on FTE.scraprat has a great reputation on FTE.
Quote:
Steve
Thumbs up, bugs came right off using the wet sheets.
  #12 (permalink)
Old 05-13-2012, 05:14 PM
RV_Tech's Avatar
Quote:
You doubted me? I'm crushed!
__________________
  #13 (permalink)
Old 05-13-2012, 06:52 PM
LibTimothy's Avatar
LibTimothy LibTimothy is online now
LibTimothy is a splendid one to beholdLibTimothy is a splendid one to beholdLibTimothy is a splendid one to beholdLibTimothy is a splendid one to beholdLibTimothy is a splendid one to beholdLibTimothy is a splendid one to behold
I just bought a box of dryer sheets just to clean my RV. I hope i get time to try this before my next trip.
Will the cheap sheets work?
Timothy
__________________
When the only tool in your toolbox is a hammer, every problem starts to look like a nail.
When the only tool in your toolbox is dynamite, you start looking for excuses to solve problems.
  #14 (permalink)
Old 05-13-2012, 07:00 PM
RV_Tech's Avatar
Timothy
I'm not sure brand makes a difference. I just steal whatever my wife has in the laundry room, use em, then sneak the rest back. Sometimes I forget and she finds them in the garage.
Steve
__________________
  #15 (permalink)
Old 05-13-2012, 08:54 PM
rvpuller's Avatar
rvpuller rvpuller is online now
2013 Ford F-350
rvpuller has a good reputation on FTE.rvpuller has a good reputation on FTE.rvpuller has a good reputation on FTE.
First I never power wash the front or any other part of our trailer it's just to hard on the decals. I always keep a good wax job or in my case a polish job (I use Nu-Finish polish). When I get a load of bugs I rehydrate them with water or a light solution of water and Dawn soap, I reapply ever 15 minutes and use a brush to clean them off, if it's really bad I use Simple Green and a sponge and polish the front because the Simple Green will remove any wax or polish. The longer you leave them on the harder they come off and some of the little buggers will damage the finish.
Denny
__________________
2013 F350 Lariat SC DRW 2WD 6.2 4.30 Gears
2003 HH Premier 35 FKTG
Retired 2000 F350 Lariat SC DRW V10 4.30 Gears BrakeSmart
Air Lifts 4X2
Tags
2012, 5th, bug, clothes, cover, f250, hang, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
