Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Transmission Guides
- How to Check Your Transmission Fluid
Step by step instructions for do-it-yourself repairs
finally did my transmission fluid change today.
With the thermostat inside trans is it even possible for me do service my trans properly with out the dealer? Does the trans flush replace the fluid inside the torque converter? I have 34k miles & last year dealer "did the fluids". I'm guessing they may have just drained pan & refilled. I want to do what is absolutely best for the truck. Thank you much.
Mark is right. At 165 to 170 degrees, an internal valve will open n allow the tranny fluid to flow around freely. Ain't no way we can maintain tat temp without scalding ourselves. Hence the heated flush machine. Those things flush everything n put back as well. However, I'm fine where I am. I'm gonna change out my tranny fluid again at 10000 miles cos the one I changed was burnt. I'll be OK. Even changing the internal filter was a little much but I'm glad I did cos the previous owner did nothing on maintenance. Lol.
Since i plan to change the internal filter i figure it would be simple to drain the torque converter and dump all or most of the fluid. Is there something I'm missing here? My handy dandy Chilton manual states that to drain the torque converter and replace the plug with new one. Any thoughts why to replace the plug?
When adding the new oil, approx. 17 quarts, do I pour all 17 down the dipstick port? The manual said initial add is 6 1/2 quarts and check from there. Seems like a slow process.
I plan to at least measure quanity that comes out to have an idea of what goes back in. Also, said after a favorable stick reading to run through the gears with foot on break.
Is that it?
Is that it?
