Block cracked or not
Old 03-19-2012, 01:57 PM
oh2bnok's Avatar
oh2bnok
oh2bnok is offline
I have a 53 v8 flatty in a f-350 that has probably been sitting for 25 yrs. It ran when parked (LOL) any way does any one know how to determine if the block is not cracked without tearing it down or even having it running. I don't know if it is possible but thought I would ask I would like to restore the engine lastly running or not. Thx
Old 03-20-2012, 11:25 PM
fixnair's Avatar
fixnair
fixnair is offline
You can pressurize the cooling system and see if it holds pressure. Of course this will not identify where the leak is but it will tell you if the cooling system is tight. Pull the spark plugs out and you might be able to see/hear coolant leaking into the cylinder. A good radiator shop will have a tool for this.
Old 05-07-2012, 06:18 AM
f5fordgirl's Avatar
f5fordgirl
f5fordgirl is offline
If the cooling system has been full of coolant all these years, and the engine is not stuck, its not cracked between the valves.
Old 06-09-2012, 03:53 AM
Snowking's Avatar
Snowking
Snowking is offline
if coolant system is full, oil level correct, if coolan seeping into oil will be milky colour and will be higher 9if oil not leaking out)
C.burnett1
07-11-2018 04:08 PM
uncle_jessie
12-21-2012 11:05 PM
jdstudski
06-18-2007 05:32 PM
FEmtnmax
11-20-2006 09:53 PM
strike
3.0L V6
06-25-2003 04:07 PM
Quick Reply: Block cracked or not
