NEED HELP BAD 94 Bronco Spindles
The Spindles on my truck are shot.... I can not find them anywhere have called and called.... its a 1994 Ford Bronco dana part #610443-9... can any one help me find it or tell me what i can do...Im stuck in a rock and a hard place finding them...... I do have abs on the truck....
All ready tried them they do not have the spindle i need and the link you posted is the wrong one that will not wok on my bronco.
For a short period in 93 and early 94 broncos had a different spindle set on them than the rest and so happens my truck falls into that gap..
not true about the abs on all four wheels my bronco came with abs on the front only along with 4 others that friends own... the sad face was not about abs but about not being able to find the part
I have gotten spindles at the local pick n pull. You may need to check a few trucks but once you've pulled one hub assembly, it all seems so easy. Make sure you take a breaker bar! Also the bolt pattern changed on the spindle so make sure you take that into account, as I did not! Mine were all sorts of chewed up and I found many nice ones, and the truck I eventually took mine out of had brand new timken bearings so I swiped those too. You will not find these at a parts store unfortunately.
You would either have 4-wheel ABS, or RABS(Rear-wheel ABS) There is no Front Only ABS. The Tone ring for the rear is in the Differential.
With ABS:
OEM D44 Bronco Spindle, With ABS Brake
Without 4Wheel ABS:
OEM D44 Spindle, 1993-94 NON-ABS
You need to confirm your Bill of Materials number.
With ABS:
Without 4Wheel ABS:
SleeprLegend
12-31-2009 06:01 PM
