sagging bumper!
Old 04-23-2012, 11:40 PM
mossyoakford96's Avatar
mossyoakford96
mossyoakford96 is offline
sagging bumper!
I got a 1996 Ford f150. I put a 3 inch body lift on it and when I put the front bumper brackets on with the front bumper, the bumper started sagging. Is there any way I could fix this because it makes the truck look like **** Haha
Old 04-24-2012, 12:04 AM
Midnite1987's Avatar
Midnite1987
Midnite1987 is offline
If everything is bolted on tight then you might have to reinforce the mount for the bumper. That's why I'm going to build a bumper when I get around to installing my bodylift
GNR22's Avatar
GNR22
GNR22 is offline
Fabri-cobbler
It's sagging like the part of the bumper furthest back is leaning too far away from the fender? Thats simply adjusted by loosening the bolts for the bumper and then realigning it where you want it to be and tightening back up.
Old 04-24-2012, 12:21 AM
minnesotafisherman's Avatar
minnesotafisherman
minnesotafisherman is offline
With the relocation brackets, the 2 lower bolts on each side go through the brackets and onto the top 2 frame bracket slots. The upper 2 bumper bolts just hold the bumper to the relocation brackets.
You just need to tighten the lower 2 bolts as tight as you possibly can. Did my 3" body lift last November and the bumper hasn't moved since.
Boss94
03-07-2011 08:24 PM
DOHC330MustangGT
04-27-2007 08:47 PM
CounterMaker
1999 to 2016 Super Duty
01-08-2007 08:41 PM
bobscoot000
12-19-2006 08:07 PM
1990F250LB
10-12-2004 09:52 AM
Quick Reply: sagging bumper!
