How problematic are the 2004 F150 5.4's?
I am currently in the purchasing process of a 2004 F150 S-cab 4x4. Has the 5.4 and automatic. Right around 87,xxx miles. Its at a Ford dealer for a decent price, test drove it and it runs great, only under hood noises are a light ticking coming from the 2 belt tensioners. I tested it in the usual directions, good test drive... and a little bit of heavy throttle and brake action. Everything seems perfect, its a VERY clean truck inside, outside, and underneath as well. Looks like its been very well maintained. Simply put, I want it!
Now reading here on the forums all I see are lots of major engine problems with the timing chain tensioners and other engine internals. I am a very overly paranoid person and I just need to know if these trucks are worth the risk of purchasing. I don't want to sign my soul away for 5 years of payments for the truck to randomly explode 3 months from now.
Maybe its just my pre-purchase nerves, but I wouldn't mind some input on the subject. Thank you!
My experience with my 2004
Purchased in July of last year. Had 71890 miles.
1. After changing oil and going to a Motorcraft filter it starting getting noisy in the engine area. (I suspect dealer had heavy oil in it to maybe quiet it down?) I put the 5w20 synthetic blend as recommended. Couldn't tolerate the ticking at idle, and a noise on slow acceleration.
2. New cam phasers, new vacuum parts on the passenger side front drive. 2100 dollars for these two items. (4X4)
3. Did plugs, although not required. 500 bucks due to breaking all of them off.
This was done at 73850 miles.
4. Changed rear end lube due to shudder coming from LS differential. Added MC Limited slip fluid and royal purple lube. Cured that issue @ 73777 miles.
Current miles 78400, only current issue is probable mild warped rotor. All other systems working well, thoroughly enjoy the pickup.
Ford F150, 2006
The engine started ticking the second day of a trip home from Texas.
I had some problems with it two years before that and had it to the dealership for the problem. They also wanted to do a bunch of other
unnecessary stuff, but I wouldn't let them. They did mention the cam phasers then.
But now the noise is constant and very annoying.
Well I have an 04 FX4 with the 5.4 88500 miles, light ticking noise but not too bad, so far so good as far as the engine goes, problems I've had are bearings on one of the belt pulleys went bad, rear diff shudder needed new clutches (covered under warranty), pinion seal leak, and power window fell off track. I do oil changes every 4k with motorcraft semi synthetic and motorcraft filter, have changed the tranny fluid 3x so far.
I will drive this truck till I can't any longer.
I have an 04 Supercrew bought new this time in 2004. I have 95k on it and have not had any serious problems. Still on my second set of tires, second battery, brakes. Oh, I had to replace a couple of power window units. Do not buy these used. It still looks to me like a new truck. Wear and tear is hardly visible. Could not be much happier with the quality.
I don't care for the ticking either, but mine is there and it has been the same the whole (almost)7 years I have driven my truck. There have been a lot of posts on here of guys running heavier oil to lose the ticking. I don't know, I actually ran 10-30 in my truck for one oil change when I first bought it because I was from the school that thought 5-20 was too thin, then my brother told me that he had heard you shouldn't do that cause the oil was too thick on start up, so then I switched and ran 5-30 for about 35,000 miles, no change, then when my Wal-mart started carrying the MC oil I decided to change to the recommended 5-20, been on that for almost 30,000 miles. I have seen change in the ticking through all that. Also, my truck has never used a drop of oil either. So, I would recommend just running the 5-20, but my recommendations aren't worth much!
I can't help you on the running boards, mine are factory, but I am sure if you shop around on-line you will find some options you like, maybe start a new thread asking some guys about after-market running boards. I maintain my truck too, I have stated to other people that I will run my truck till it blows, like you I hope that is a long time. I try to maintain it, and I am obsessed with keeping the outside looking good(too obsessed most would say). I love my truck and I have driven it almost 7 years now, I would love to drive it another 7, and I will as long as the engine stays strong and the exterior stays in good shape.
