Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-16-2012, 03:11 PM
sloroller sloroller is offline
Garage is empty, add now
sloroller is starting off with a positive reputation.
need advise for first start/break in procedures
so I'm getting ready to fire up my 352 and have comp came additive but what oil should I use 10/30 30w or 15/40? thanks for the help and advise!
  #2 (permalink)
Old 04-16-2012, 05:55 PM
69cj 69cj is offline
69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of
15W40 is a diesel oil. Just use the 10W30 and prime the system prior to start up. Yank dist. and run the oil pump with a drill motor till you see oil coming out of the rocker shafts.
__________________
"05 F-250, 6.0, CC, LB, 3.73, 4 X 2, Lariat, with coolant filter and Bilstein shocks, Magnefine p.s. filter, Ford fuel press. spring upgrade and ScanGauge ll. S. Ca.
"69 Mustang, Mach 1, 428 CJ, Ram Air, Stock
2007 FHLP H.D. Road King
2007 Thor Jazz 5er, 11k dry weight, 31'
173rd Abn. RVN.
  #3 (permalink)
Old 04-17-2012, 12:30 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to all
I would find a 10W30 that still has a high ZDDP (zinc dialkyl dithiophosphate) content. Prepressurize the oil system like 69cj said. Once you start it, it's important to bring the idle up to 2500 RPM and keep it there for about 20 minutes. Vary the RPM occasionally but don't let it go below 2500RPM.
Check for any leaks and don't shut it down unless you have to.
Once the 20 minutes have passed drop the idle down to 1200-1500 RPM for another 10 minutes then set the idle to specs.
Once you're satisfied everything is okay, change the oil and filter, again use an oil with high ZDDP content.
All of this is to be sure the cam is properly broke in. It's important to keep using this type of oil in flat tappet engines or else you lifters could look this in short order.
  #4 (permalink)
Old 04-18-2012, 12:32 AM
CliffBerger CliffBerger is offline
CliffBerger is starting off with a positive reputation.
That's good advice, thanks
  #5 (permalink)
Old 04-19-2012, 10:30 AM
yellow truck's Avatar
yellow truck yellow truck is offline
1969 Ford F-100
yellow truck is starting off with a positive reputation.
You can use the Lucas break in additive, it adds ZDDP.
Once you have primed it and started it, warm it up, and take it out and beat on it really hard. You need high compression pressure to spread the rings into the walls of the cylinder, and you get this by a series of hard runs from standing start to max speed, then back down to a stop and do it again. Do that for about 50 miles, then change the oil and filter, and drive it hard frequently for the next 1,000 miles.
If you don't you run the risk that the oil glazes on to the cylinders and you never get the rings to seat. The cross thatching that was put in the engine in the machining is mean to be worn in by the rings to get maximum seal, glazing prevents this.
__________________
Paul.
1969 F100 4WD - 410 (not yellow anymore)
Tags
40, 62, 64, block, break, diesel, ecoboost, f150, f250, ford, liter, procedure, rpm, short, starts, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
