Thermostat housing bolts
Old 05-18-2012, 06:07 PM
Epd444's Avatar
Epd444
Epd444 is offline
I'm in the middle of changing my water pump, and the three bolts that hold the thermostat housing to the water pump snapped off when I tried to take them out. Anyone know the thread size? It's the 3 bolts that connect the thermostat housing/neck to the water pump itself.
Thanks.
Old 05-18-2012, 07:25 PM
pjwoolw's Avatar
pjwoolw
pjwoolw is offline
Stolen from Jose: The bolts are: flange bolts M6 1.0 pitch and 20 mm long.
I used allen heads on mine. I found them easier to install. Stainless is best.
blageurt's Avatar
blageurt
blageurt is offline
I think it is a M5...... could be a M6 however...... I would have to go outside and measure one .... They are like 2 cm long with a 8 mm head similar to the fender bolts with a smaller washer IIRC
Old 05-18-2012, 07:43 PM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Lightbulb
Please confirm.
I have this saved in my PC
IH part number for the bolts: 1817817C1 and they were .21 cents each, $2.71 out the door including Tax...( for 12 bolts)
the updated Ford part number is W300005
The correct bolts are metric M6 X 1.0 X 20mm long, grade 10.9.
Old 05-18-2012, 08:27 PM
Epd444's Avatar
Epd444
Epd444 is offline
Thanks guys, another quick question
Where are you guys with intercoolers mounting your coolant filter?? I've seen the alternator braket but I can't with my intercooler.
Old 05-18-2012, 08:31 PM
madpogue's Avatar
madpogue
madpogue is offline
^^^^^ Always the option of the IH water pump with the integrated filter mount.
Re. the 'stat housing, somewhere knocking around online is a kit with a hard steel "flange" that sits behind the regular housing flange, and a set of longer bolts. Supposed to make for a better seal (housing flange doesn't bend), and I suspect the bolts would come out better next time.
Old 05-18-2012, 08:35 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
In the upper part of the firewall, near to the brake booster or in the inner fender drivers side below of the hinge
Old 05-18-2012, 08:48 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
here is a pic in the fender
Old 05-18-2012, 08:50 PM
madpogue's Avatar
madpogue
madpogue is offline
^^^^^ Right next to the PCM and IDM? Check those clamps.....
Old 05-18-2012, 09:01 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
I got your point, maybe the other location I mentioned is better.
Old 05-18-2012, 09:04 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
Old 05-18-2012, 09:39 PM
BuckHammer's Avatar
BuckHammer
BuckHammer is online now
My clutch fluid reservoir is occupying that space.
Old 05-18-2012, 10:40 PM
oldbird1965
Is that true on all manual's or just your conversion?
Old 05-19-2012, 05:22 AM
DZL JIM's Avatar
DZL JIM
DZL JIM is offline
PREMIUM SPONSOR
That's where the master cylinder goes. If you look on your truck with automatic, you'll see an oval plate with 2 bolts, that comes off and master goes there.
I hate those water neck bolts. I had one break on me a couple years back and I got some threaded rod and nuts. Cut short pieces and threaded them into the water pump as studs, and used the nuts with lock washers to faten the neck down. Never have to worry about stripping those bolt heads or breaking them off in the pump ever again.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old 05-19-2012, 06:03 AM
redman84's Avatar
redman84
redman84 is offline
You can take the jack out of its spot under the hood and put a filter there.
Quick Reply: Thermostat housing bolts
