Quad 7-Inch Headlight Grill
Old 07-01-2014, 12:16 AM
Jklnhyd's Avatar
Jklnhyd
Jklnhyd is offline
I have a grill like that. You could tie it in with a switch, and hook em up to your floor high/low switch
I drank about 6 Virgin Screwdrivers, im heading to bed. Gnite
  #32
Old 07-01-2014, 12:32 AM
buckin69bronco's Avatar
buckin69bronco
buckin69bronco is offline
Ok here is where I am at... no photo shop involved Although if someone wants to add in some grille inserts please do so.
  #33
Old 07-01-2014, 01:44 PM
1972RedNeck's Avatar
1972RedNeck
1972RedNeck is offline
If you just add four more lights you won't need a grille insert.
  #34
Old 07-01-2014, 07:46 PM
Jklnhyd's Avatar
Jklnhyd
Jklnhyd is offline
^^^hahaha!!😂😂😂
Your license plate can be "WNDOLKR"
  #35
Old 07-01-2014, 10:26 PM
79 Crewcab 4x4's Avatar
79 Crewcab 4x4
79 Crewcab 4x4 is offline
As much as I'm not grooving to the 4 light idea, after actually seeing it without the grille, a hideaway headlight grille with the flip covers could be interesting..... phantom it out.
  #36
Old 07-01-2014, 10:51 PM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Moderator & parts seller
Received 3,288 Likes on 2,444 Posts
Get 2 sets of grill inserts, mold the far outer headlight ring to the inner light and the corresponding grill bars. I like the 1st pic 73 grill bar line look, versus the 2nd pic 76-77 grill inserts.
Cool idea all the same, dare to be different, I dig it.
  #37
Old 12-21-2014, 09:35 PM
buckin69bronco
It's been a long process but I finally finished the grille inserts to go with the quad headlights. The outer lights are normal high/low and the inside light will be hid to use as brights.
  #38
Old 12-21-2014, 09:54 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
That is friggin' AWESOME. Good job! And thanks for following through.
Can you describe how the headlight rings were formed and how the bars and braces were assembled? TIG welded? Is that "walkway grate" as someone suggested earlier?
I'm gonna include this in the next update Tech Thread Compilation...
  #39
Old 12-21-2014, 10:30 PM
buckin69bronco
The rings were made from 2 x 1/8 x 25"ish aluminum flat bar that was cut on a bandsaw to ark from 1" to 2" and back to 1". It was then formed around a wooden die that was 5" dia. With springback this made 8" rounds that were 1" wide at the bottom and 2" at the top.
The rest of the grille was made from 1 x 1/8 flat bar. There are 3 vertical support bars that have 1/8" slots cut into it at 12 deg to match the slope angle that the rings create.
It was all welded with a spool gun hooked to my mig welder... This welds ok at best and a tig would be way better.
The leading edge of the grille insert was polished and the rest is flat black.
Hope this makes sense.
  #40
Old 12-21-2014, 10:32 PM
TheStuffz's Avatar
TheStuffz
TheStuffz is offline
wait.. ive seen this somewhere before lol
  #41
Old 12-21-2014, 11:27 PM
HIO Silver's Avatar
HIO Silver
Yes that makes perfect sense.
Wanna make me one? Just kidding. I know how much work and azz scratching it takes. Congrats on your stick-to-itivemess and getting it done. For sure it's one of a kind.
  #42
Old 12-21-2014, 11:58 PM
my-ford's Avatar
my-ford
my-ford is offline
i love it lol...i would love to convert this grain truck grill to my 77.but i think it would be a lot of work and fabrication.we have this same grain truck but green sitting in the Field.we just cleaned up the property and pulled it off a tree that attached its self to the bed lol. front tires still have air in them.motor still turns after 38 years...just cant beat the old days when a truck was a truck and not fine china...
  #43
Old 12-22-2014, 01:13 AM
rockittsled's Avatar
rockittsled
rockittsled is offline
Looks good! I had made a comment one time to HIO about using that headlight setup as a base to create a FAUX Mercury-100, adding luxury items like power leather seats, power windows, power everything else. Sort of like the difference between the Mustangs and the Cougars in the late 60's while they shared the same platform
  #44
Old 12-22-2014, 04:29 AM
trozei's Avatar
trozei
trozei is offline
You're going to have a lot of people doing double takes when they see this out on the road.
  #45
Old 12-22-2014, 10:39 AM
monkey-1's Avatar
monkey-1
monkey-1 is offline
I like the way that looks!
I have seen a 76-77 with quad square headlights. I will try to get a pic of it when i am back that way.
Quick Reply: Quad 7-Inch Headlight Grill
