Flathead vs. 302
I love my Flathead, and with the fenton headers and Smitty mufflers 41phord is exactly right....it is WAY cool !! Here's a photo during the original build. Obviously the 12 Volt swap (alternator), the MSD Ignition etc. The build of this motor setup was expensive because to accomodate the MSD distributor I had to locate truck water pumps as they had the extended pulleys to allow the fan belt clearance etc. Basically, if you're going to go this way on a flatty. Plan for extra expense.
On the other hand, now I'm cutting out the original front cross member, I have to cut the original firewall out and install (in my case) a 4" recessed firewall to accomadate the 302 (most say a 2" recess is enough). The I'm putting in a new front cross member, IFS and power rack and pinion.
So either way you go....It's not cheap.
And YES....the flatty, drop axle, split wishbones, C-4 and rearend are Pink. And the new 302 will be .....Pink !
Hey guys! I've noticed some posts about changing out the original flatheads for a 302/351. I wanted to know about what kind of driveablility issues anyone has experienced with the flatheads, and reasons for deciding to upgrade. I'm starting a project, and thought keeping the flathead would be kind of neat, but have never actually tried to keep one running during regular driving. Any input would be greatly appreciated. Thanks!!
He still has one of his coupes with the fast flatty (detuned) in it, I will say this.....having driven and work on them (for the past 40+ years), they are/can be brutally fast no matter what any book writer expert will say, they are driven different because the hp is typically lower by comparision but the tq is incredible.....means the gears need to be tall by comparison (dad use to run 3:55's for the 1/4 mile as an example)...and he is running 3:55's presently.......in terms of accel, (now mind you his is hopped up) there is not difference between 1st & 2nd gear (running a 3 speed with High Zepher gears)...and 3rd, well, you could take off from a stop if you wanted too, downshifting, never required.....
After hearing from several members, I've decided, for now, that I will try to go with a 49 and later flathead, since ther is an aftermarket bell housing available to mount a T-5 to it. I like the style of the old flattie, painted, with aluminum heads, then sanded so the fins show as polished. I'll probably go with the MSD ignition, and I've seen a kit to mount power steering to it. Since one of the trucks is missing the front suspension anyway, I will probably go with an IFS kit. I know some members will consider this "dark side", but I think it really does come down to personal choice. And, after all, the one truck is missing some of the parts anyway, so that would be a good time to upgrade. I will, however, be saving all the parts I don't use, so that if a "purist" comes along and wants to save one more example, I would be more than happy to defer to one whose restoration skills would be better than mine. I know these parts are kind of rare, and would hate to throw anything useful away! At any rate, this will all be down the road a ways, probably after the kids are out of the house.
302 swap
My 1940 had a flathead needing a rebuild. It would cost about $6,000.00 to do that, way too expensive. A new edelbrock intake alone costs 1500, for that price I got a 1968 mustang 302 and a c4 rebuilt.
also, I found speedway motors has engine mounts and bumpers that work well, they mount to front heads in exact same location which allows you to use the flathead original mounting locations. no welding.
Also got an alternator bracket from march ($60) and a 90 degree water neck ($12, oreilly), with an a/c bracket ($90) from nostalgic air parts, and a cvf racing wp pulley ($80), summit electric fuel pump ($70) and you have a modern setup.
used a 1968 mustang radiator to match, etc... 2 bbl carb off ebay ($75).. parts on ebay are plentiful.
the only way I would keep the flathead is if it was already running well or you had a VERY original car.. once you add up all the extra flathead upgrades it is not worth it for twice as much money and half the power.
best of luck,
mpr
best of luck,
mpr
reed1951
23
09-23-2008 08:05 AM
jondirt
04-22-2004 05:41 AM
