Wanting 350-400 hp
Wanting 350-400 hp
I have an 03 f-250 with the 5.4. I would like to get in the range of 350-400 hp. I have been looking into doing a cummins swap or just getting the motor built to do it. I would rather have the motor built to do it since it seems it would be cheaper and more sensible. What would the motor require to pull this off. Thanks
I have cold air intake, programmer, exhaust already. I have the rest of the truck built the way I want it so I'm not wanting to get a different one. I don't like keeping things stock. Would cams and aftermarket heads net me in the 400 range and what would I have to do about programming the computer for this.
Sounds like you need supercharger or turbo to get the numbers you are after. Look for a wrecked lightning. Start buying the go fast goodies off of it. If you have an 2003, I am sure it has some miles on it. You might want to consider how the bottom end of the motor is going to hold up to all the extra ponies you are going to strap to it.
I would visit some lightning forums, and mustang forums. It is easy to accomplish, but not cheap.
Like the old saying, you want to go fast. How much money do you have?
I am in the current state you are. I have an 2004, and when my motor goes it is going to be getting a transplant. Just not sure which one yet. I am probably going to go with a 12V cummins swap on mine.
With a truck this big, it is not about HP. It is all in the Torque.
In stock config the 12V with a little fuel work, from what I have read, will net 460 ftlbs of torque. That is a heck of a step up from the 2v 5.4. With more goodies it is capable of a lot more than that.
If you are planning on keeping your 5.4 than a lightning or a Harley truck with the supercharger would be a good place to start sourcing parts from.
Good luck on your build. I was thinking of going this way as well, but my engine just has to many miles on it to start bolting on that much hp.
There is no easy or cheap way to build the 5.4L engines. Are there aftermarket parts? Yes. There are cams, headers, superchargers, etc. for the 5.4L engine but 99% were designed for the F150 or Mustang. Will those parts fit your Super Duty? Yes, with some modification.
There real issue is that very few people go this route with the Super Duty. Hence, it will be a "trail & error" project for the builder and that means $$$. Most of the supercharger kits include a tune for both the engine and transmission. However, the tune is not for the 4R100 transmission. So, you will need someone like Mike at 5 Star Tuning to tune both the engine and transmission. Also, that 4R100 transmission will need to be made bullet proof to stand up to the new HP/TQ.
You most likely will need to upgrade the internals (crank, rods, pistons) be maintain reliability. That is another significant cost to the build.
I was looking at installing a Whipple supercharger on my 2005 F350 5.4L 3V engine. I took quotes from two custom engine shops and they were $15K and $20K. My Super Duty is like brand new with only 38K miles but the new engine build was more than my truck was worth. Now, I am at a complete stand still. I don't know what I am going to do.
A supercharger will get you where you want to be on a fairly low amount of boost.(around 5-6 lbs) The stock bottom end will hold 5-6 lbs ok with good tuning. The stock powdered metal rods are the weakest link. The SC will give you gains in both hp and torque. Headers, exhaust, intake and etc alone will not even get you remotely close to your power goals. Throwing a set of heads and a cam on the engine is pointless without replacing the stock intake manifold and doing so will shift your power up higher in the rpm range which is not really ideal for a working truck.
