79 F600 4x4, converting to air brakes
I am slowly building a 79 F600 4x4, I am putting a 460 in it, lifting it and going to run16x20 michelin tires. I am tired of trying to fix the hydraulic brakes and want to convert to air brakes. I have access to a 900 series 5-ton military truck axles that have air brakes, what would I need to convert the rest of the truck. Any ideas on what to use for an air pump? This truck will have a pickup bed on it and be more of a toy but I want to be able to stop those big heavy tires, any help is appreciated.
Converting to air brakes will be quite a task.
Mounting pump
mount primary & secondary tanks (wet tank if desired)
installing gauges
low air lamp
push pull dash valve for ebrake
dual circuit treadle valve
front brake qr valve
rear brake relay valve w qr.
rear brake qr for the e brake
All the hoses and brass in between.
The hoses and fittings alone will probably cost over 500. Add in the valves, and tanks and you'll easily be up over 1000.
A parts truck is highly recommended.. Damn brass kills on projects like this..
Mounting pump
installing gauges
low air lamp
BigBlockBill460
02-24-2005 01:36 AM
