1995 7.3 Powerstroke won't start
#31
FYI the glow plug light that you mention is the WTS, no for the glow plug itself, they can cycle till 2 minutes.
BTW welcome to the forum
#32
After blowing the #22 fuse a couple of times, I disconnected the fuel heater in the filter bowl by unpluging the top connecter on the driver side of the fuel filter bowl.n Put in a new fuse and it seems to be working. I have a 95 7.3 turbo.
Thanks for the help. The forum saved me from taking it in paying a big bill.
#33
#36
#38
my 95 f350 is doing the same thing did u figure out the problem
#39
I have a 1995 7.3 f250 and it's doing the same thing
I pulled the fuel heater out and put it all back together and put a new fuse in it and it blew the new fuse. I read on another forum that you can test the pcm by unplugging it and putting a new fuse in and if it blows that one than it's not the pcm. I'm stumped, I have no idea what is going on with this truck and I've been working on it for 2 days and still can't figure anything out. A little help would be nice
#41
#42
First of all, welcome to the forums! You will probably get more responses if you would start a new thread, instead of piggy backing it on a 5 year old thread. That said, did you unplug the heater wire and tape it up, so there is no chance of the wire shorting to ground? Did you inspect the wire to see if there are any breaks/bare spots in it, where it could short out? While the fuel bowel heater is usually the cause of fuse #22 blowing, the harness can be breaking down from oil/fuel soaking the insolation. Inspect the harness closely.
#43
1995 f350
I have a question, I got a 1995 f350 and I had a buddy do a full rebuild on it and it wont stay on by it self. It act like it isnt getting fuel. I turned it on with either. I bleed it I replaced the pump dropped the tanks clean them, checked the fuses I have singal to the injectors, I just cant figure t out I know the motor good it fired up with a lil ether but by it self it wont
#44
