I have a 1994 f150 and the frame is beginning to crack and i wanted to know
1. What causes
2. Should i worry
3. What can be done to fix it
here is a.picture of the crack it is started where the frame is shapped around the shock
Have a COMPETENT welder do his job, and there will be nothing to worry about. if you let it go, chances are the crack will get bigger until it brakes the frame in half
