2002 7.3L boggs down then goes when I let off the pedal.
Old 04-12-2012, 05:31 PM
tommy1ton's Avatar
tommy1ton
tommy1ton is offline
I have a problem with my truck on cold mornings. Shortly after starting, I hear a whooshing noise in the dash area, and it gets louder if I push the accelerator down slowly- plus the truck will not accelerate while this noise is happening. If I back out of the throttle completely until the noise stops, and then push the pedal down aggressively, ,it accelerates just fine until the speed catches up to the rpm, and then the noise and lack of response comes back. This happens until the truck is at operating temp for a while, and only happens in the winter, when temps are below or at freezing at night. Anybody ever hear of anything like this? It's driving me nuts
Old 04-12-2012, 05:34 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is online now
9 ECHO 1
EBPV - Exhaust Back Pressure Valve.
It increases load on the motor to warm up faster. Instead of driving right away, allow your truck to warm up before driving.
Old 04-12-2012, 05:37 PM
tommy1ton's Avatar
tommy1ton
That's it? It's operating properly? I just have to wait? Thanks Trey, I'll try it!
Old 04-12-2012, 05:39 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is online now
9 ECHO 1
Yupp thats it. There is some debate as to whether or not it should be operating when on throttle, but other than that its operating properly.
Old 04-12-2012, 05:40 PM
tommy1ton's Avatar
tommy1ton
OK, when I let the truck idle for very long, it suddenly increases in rpm and makes a loud exhaust sound- what's that about?
Old 04-12-2012, 05:41 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is online now
9 ECHO 1
Could be high idle. Could be EBPV. Depends on the temp.
Old 04-12-2012, 05:57 PM
tommy1ton's Avatar
tommy1ton
OK, I appreciate the info
Old 04-13-2012, 01:55 PM
crapshootersteve's Avatar
crapshootersteve
crapshootersteve is offline
Happy to report that the bogging down has stopped for the time being. I guess the fuel filter was the issue. Thanks for all the suggestions, You guys rock!
I'm new to these trucks, so all the little quick fix/preventative stuff you guys shared will definitely be helpful.
Old 04-13-2012, 02:29 PM
crapshootersteve
BIGTRUCKBIGRV
2017+ Super Duty
09-10-2017 08:36 AM
Nolo263
07-07-2013 07:34 PM
Weberman3
05-03-2012 07:15 AM
7.3 Diesel
General Diesel Discussion
08-02-2011 02:21 PM
Nathan C
6.4L Power Stroke Diesel
05-27-2007 02:04 PM
Quick Reply: 2002 7.3L boggs down then goes when I let off the pedal.
