Does anyone have experience with F350 leaking brake fluid passenger at the front axle? Any suggestions or things to look for? I filled the reservoir up twice and it leaked out.
Lots of places where it could leak if you're stating axle and not a specific location. Rusted metal line, fitting at the frame, hose, banjo bolt, piston seals.......
Do you have a helper? Refill the reservoir and have the helper pump the brakes and you should be able to track it down with a good light source. Recommend safety glasses.
Just had both front brake lines replaced on my 2006 F350. Passenger side had rusted loose from the junction bracket above the tire; when I pushed it back, it started leaking.
