390 build help and opinions
on
my brother threw a 390 together and it had 360 pistons to yield 10+ :1 CR and the biggest cam he could run on factory valve train. Stock 4bbl intake, headers till they were junk and got swapped for manifolds, and that thing was absolutely a torque monster, roll smoke off of the tires from an idle, even at 6000 ft where we are in CO. We never degreed the cam and did no work on the heads, just bolted it together and had it balanced. It wasn't a race car and really flattened out around 5000 or so but if you want to cook those 35s it would do it and not even have to spin to do it. It had a eddy 600 then an eddy 750 then a holley TA670 and it ran best with the holley but it just ran good all the time.
$1000? That's if someone else does it for ya. What I am talking about is a mild cleanup of the ports. Carbide burrs and a roll kit will only run about $100 or the roll kit alone for about $40. Invest a little time and effort and be rewarded with increased efficiency and HP.
Here's some info: Engine Porting Kit
Do it.
Do it.
ok well im pretty sure im going to do some home porting. using the gasket trick on exhuast side and little unsure if im going to do intake side. and to reseat my valves im going to try thr abrasive compound and do it by spinning a valve in there till i get a good ring around it. any input would b helpful as this is a big thing for me since ive never tried it before and my motor genius brother is saying im stupid for even trying it by myself. o and do u guys like percys dead soft gaskets. bought some for my hooker headers.
i would like to know what i would need to do and what is required, if i bought some edelbrock 60089, bare heads. i believe these ones will work they r for a 427 i have the dcomp cams valve springs, lifters, timing chain and gears, locks, cam, retainers, and seals. can i re use my old rocker system or will i need a new one and maybe a stupid question but do i even have rockers originally
in previous build, before the current one. i ran a bigger cam. it lasted for a while. but the stock rocker arm springs eventually failed-too much lift on stock rockers caused bind. i now have mercury adjustables and a smaller mid-range cam in it, doesn't lope as much, but i like it.
im curious about some of those cheap aluminum adjustable rocker arms i see on ebay for fe motors.
Boundertom
01-28-2019 10:45 AM
cws10190
20
04-11-2012 09:25 PM
jlang
09-15-2009 10:01 PM
MufassaMaxx
13
05-21-2002 05:32 AM
