Are these too far gone?
I recently rebuilt my front leaf spring packs. 54 F100 with a 223 6 cyl. I removed a few leaves per the instructions on the mid-fifty site, cleaned up the remaining ones and reinstalled with new hardware (bushing, shocks, etc). Now they look overused/overextended, the arch is almost going the opposite way. I don't know much about these trucks and not sure if this is normal. I know these leaf springs didn't have much arch to begin with but I am wondering if its time for new ones. Here are a few photos. What do you think?
Well, I wasn't necessarily looking for a "lowered" front end. My reason for thinning the original pack was due to a damaged spring. My question was does it look abnormal to have the spring back arched down like it is? I know that changing out spring packs is time and labor intensive. If I had big bucks I would have bought new springs but I was trying to get through a summer without spending a lot. Not everyone has money to spend on a daily driver.
Removing every other leaf will lower your truck, however experience tells me the truck will bounce and sway on every bump in the road. To fix that, I have found Posies dual super sliders to lower the ride the same amount, while at the same time stiffening the suspension to that of a stock leaf count. Less bounce, same lowering effect. Cost is what it is, but the ride difference may be worth it. But it's up to you on how much bounce you can tolerate.
I have heard of other folks that have had their springs re-arched but I don't know what the results were. I replaced my front springs with a mono leaf system. On my truck the po had a totally different spring on one side. For safety reasons do you think you should consider new springs or replacements? I wouldn't want to trust those you have there.
