Poly Cab Bushings
Poly Cab Bushings
Anybody have any luck with these? I've been told that they'd be harsher because they're harder than the OEM bushings. I've actually installed a few sets myself on a few 90's Fords and I was impressed with them. I can't really say I could tell a difference because the trucks were riding on the frame rails before I put bushings in them. Only reason I put the poly bushings in these trucks was because the $70 vs. $250 kinda made it an easy pick.
The bushings on my '99 are shot... the cab has settled pretty good and I've got a knocking under my floor. It's not when I hit big bumps, it can be very rapid as the road vibrates the truck. I've gone through everything under the truck and it's all tight so I know it's the cab bushings. Anybody ever used the poly bushings on these trucks?
i plan on installing a set on my 2004 F350 this summer, i too was looking for someone who did this on a Super Duty with no luck. Ive installed energy suspension body bushings on my 79 Bronco, 78 f150 and 85 f250 mud truck with awesome results. ride was no worse then stock and a hell of allot cheaper! i assume your installing daystar since they are the only ones who make them for SD's?
KF04014BK Body Mount Bushings
understood, right now i have probally 1/2 to 3/4 inch between my frame and body on my F350? seems a little low to me but i dont hit or rub yet.... just figured since it has 100k now and i cant afford nor want a new i cant fix my own new truck because i need a ten thousand dollar lap top to figure out whats wrong, id just pamper mine!
