1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
F250 & F350 why did Ford make them the same?
Old 04-04-2012, 08:38 PM
RussF350's Avatar
RussF350
RussF350 is offline
From what I understand the F250 & F350 are the same truck with the exception of the blocks in the F350. I have an F350 which I bought because I like knowing I can put lots and lots of weight in the bed (if you're gonna buy a truck you may as well go all the way). So does the F250 really have all the same suspension, springs etc.? Just a different sticker on the door? Why does Ford do this? Makes no sense to me.
Old 04-04-2012, 09:13 PM
jmiley's Avatar
jmiley
jmiley is offline
Rear springs and rear blocks are different, other than that, they are the same.
The 350 SRW will ride quite a bit stiffer empty, than a comparable 250.
Old 04-04-2012, 09:33 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
Because in many states 10,001 lb vehicles and above are commercial vehicles only. So the sticker has to be different.
Gotta fit inside the law
Sam
Old 04-04-2012, 11:09 PM
Nadster's Avatar
Nadster
Nadster is offline
The rear axle on the F350 is a little larger and has 37 splines at the hub end. The F250 has 35.
Old 04-04-2012, 11:31 PM
dchamberlain's Avatar
dchamberlain
dchamberlain is offline
All of the rear end parts on an F-250 and an F-350 SRW are the same, including the main spring pack, with two exceptions. The F-350 has taller blocks, and the F-350 comes standard with the overload spring set above the main spring pack. The axles are identical.
The F-350 DRW uses a different axle, etc.
Old 04-04-2012, 11:45 PM
Kajtek1's Avatar
Kajtek1
Kajtek1 is offline
and this is what separate workhorse from grocery getter.
The note about legal limits is valid as well
Old 04-05-2012, 06:46 AM
Coz77's Avatar
Coz77
Coz77 is offline
I was told that getting the Camper Package basically made my 250 a 350 with the extra spring for the camper certification. Don't know if they were blowing smoke or not.
Old 04-05-2012, 09:17 AM
dchamberlain
The camper package got you the extra spring (and front and rear sway bars), but not the taller blocks. I don't believe it changed the GAWR or GVWR, but I won't swear to that.
My truck is an F-250 with the extra spring and sway bars and it's GVWR is 8800.
Old 04-05-2012, 10:17 AM
Coz77's Avatar
Coz77
Coz77 is offline
When you speak of blocks are you talking about the blocks for a lift kit? On my 99 with the camper package it came with a factory 2 or 4" lift.
I also ordered the 10000/9900 GVWR package on the new vehicle. It was a $0 option.
Old 04-05-2012, 10:23 AM
dchamberlain
The stock blocks between the spring pack and the axle. I didn't know you could order different ones. That's interesting.
Old 04-05-2012, 10:58 AM
TexasRebel's Avatar
TexasRebel
TexasRebel is offline
you can't order different ones... they are specific to the pickup you buy.
F250 4x2 gets no block
F250 4x4 and F350 4x2 get 2" blocks
F350 4x4 gets 4" block
SRW of course. DRW is different.
Old 04-05-2012, 12:52 PM
Coz77's Avatar
Coz77
Coz77 is offline
I understand. Mine was a SRW.
Old 04-05-2012, 04:19 PM
kas83's Avatar
kas83
kas83 is offline
Ive seen many early 99 F250 4x4s with 4 inch blocks, all diesels with the engine badge on the fender.....
I'm fairly confident that early 99s all came with the taller blocks, since I remember seeing a TSB about shorter blocks for those pulling 5th wheels.
Old 04-05-2012, 04:46 PM
FordGuy85's Avatar
FordGuy85
FordGuy85 is offline
Iv got a early 99 250 with 4.0 blocks in the rear and 3 leaf springs per side up front. I believe it is f350 suspension. When my truck was made, a true f350 had a Dana 60 front axel up front. My truck has the dana 50 up front with a 10.5 rearend out back. Oh also there are 6 springs per side over the rear axel not counting the over loads underneith them. I believe this is f350 suspension on a f250. Custom ordered by the previous owner. So there are more differences between a f250 and f350.
Old 04-05-2012, 04:48 PM
TexasRebel's Avatar
TexasRebel
1999 was an odd duck... the mirrors also don't telescope.
Quick Reply: F250 & F350 why did Ford make them the same?
