Balance beads
#46
No.
$9/tire and an install kit Amazon.com: Dyna Beads Applicator w/Spout: Automotive
Dyna Beads Refill Bag | ATV | Rocky Mountain ATV/MC
Sam
Sam
THANK YOU VERY MUCH
#48
#49
That's what I am wondering about. If I use the Walmart soft pellet method, do I weight the tire and wheel combo and put a certain amount of weight per pound or do I take he amountof wheel weights I currently have on the wheels and add that per tire? I run BFG all terrains and would love to ditch the wheel weights off my aluminum wheels if possible.
#51
remember that the beads will have a larger leverage effect cause they are another 6 inches away from the wheel center.
they typically did 1 bag per tractor trailer tire. I don't know what size that is.
Sam
#52
#53
i would also say it depends on the kind of tire. With my boggers i am going to use more than recommended cause they are so bad. In my experience big rig tires are shaky but not as bad as a big mud tire so i would use recommended amounts. i emailed the company that made that chart and they said use 12 oz per tire for mine. they weigh in at 100 lbs or so.
#54
#56
#57
spin, put weights on,
spin... oops need weights somewhere else
etc
etc
etc
I had a tire with a bad tread.. they tried to balance it first, even tho I told them beads were present.. it was fun to watch for 30 minutes
Sam
#58
Edit: Thanks Sam, that's what I was wondering. Odd that they won't balance on the machine, but will on the truck. Perhaps they need some road bounce to help distribute effectively.
#59
The beads may not work on a machine because they don't allow the tire to oscillate with the unbalance. When I get my 37s I'll have them balanced with weights and will add the beads later if they get out of balance. Balancing them first with weights will make it so less beads are needed later on.
#60
You would have to spin balance them first, put your hang on weights on then fill them with the beads. A spin balancer will never spin them fast enough to disperse the beads where they need to go. It take about 35 to 45 mph to disperse the beads, up to that speed you won't notice if the tire is out of balance anyway. The point is you never feel it happen they just automatically balance.
