Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 04-03-2012, 09:10 AM
smokin7.3 smokin7.3 is offline
Garage is empty, add now
smokin7.3 is starting off with a positive reputation.
Newbie loss of power while passing
99 f250 7.3 losses power when i try to pass or just get on it wot,no smoke seen,no codes showing, ideal good and revs up good out of gear, but when trying to pass it just bogs down and very little passing, fuel filter and air filter changed a couple months ago, i have had very little problems with engine, gem replaced 2 yrs ago,trans 4 yrs ago, not sure if i'm looking at a fuel problem or sensor problem, any guidence would be appreciated, thanks
  #2 (permalink)
Old 04-03-2012, 09:38 AM
Deluxe06's Avatar
Deluxe06 Deluxe06 is offline
4000 rounds a min
2000 Ford F-350
Deluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to behold
How many miles on truck ? Have you done the in tank mods ?
__________________
Richard PAA#119
00F350CCDually;7.3L;ZF6,4"MBRP;DIY5"Tailpipe;Modde d Turbo 1.0 exhaust with Ported Shourd;EBPV as exhaust brake;Custom Air Intake with 6637;T500 HPOP;DPTuner-Stock,60e,80e,60t,80t,120r; 6.0 Intercooler;SBC;FRx;HRx;OCR;Bellowed Up Pipes;GlowShift Guages,Boost,EGT;AE, B.E.S.T map
  #3 (permalink)
Old 04-03-2012, 09:48 AM
258,000, I haven't started yet, trying to see what is the best to start with.
  #4 (permalink)
Old 04-03-2012, 09:52 AM
checked codes last night after this happened, no codes showing, started checking sight to see if any else had this problem.
  #5 (permalink)
Old 04-03-2012, 10:02 AM
kawcrasher's Avatar
kawcrasher kawcrasher is offline
kawcrasher has a good reputation on FTE.kawcrasher has a good reputation on FTE.
Lack of fuel pressure, HPO, or boost come to mind but we need a lot more info.
What scanner are you using? Most will not read the 7.3 codes. We will need boost, fuel and HPO numbers to even start. Anything else will just be guessing.
__________________
2000 F-250 Ext Cab Flatbed PSD auto 4x4-Diy intake, T-500, PHP tunes, 4" Diamond Eye Exhaust 360,000
2002 F-350 Crewcab SWB V10 Auto 4x4-My car.
1995 F150 Reg Cab 300 5spd 4x4-Sold-Best car I ever had
  #6 (permalink)
Old 04-03-2012, 10:09 AM
Deluxe06's Avatar
4000 rounds a min
2000 Ford F-350
Sounds like you might have plugged screen in the tank. Try to blow some air back threw the fuel line, pull the line at the pump and blow air back into tank.
__________________
Richard PAA#119
  #7 (permalink)
Old 04-03-2012, 10:16 AM
I'll go and try that, I have the actron obd ll auto scanner and thanks for the info
  #8 (permalink)
Old 04-03-2012, 10:53 AM
blew through the screen in the tank, still no go, 1500 to 2500 rpm and no get up and go, guess I'll go get a fuel pressure gauge set and check pressure and check injectors
Tags
aquarium, bogs, excursion, ford, georgia, passing, powered, review, v10, vbulletin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
