Turn siganl replacement
You'll have to know your build number because there is a production split. Check your warranty plate... Before serial G30001 uses C9TZ-13341-C.
After serial G30001 uses D0TZ-13341-B.
Visit www.dennis-carpenter.com for repro and NOS parts... $30 fpr either PN.
[quote=HIO Silver;11659340]You'll have to know your build number because there is a production split. Check your warranty plate... Before serial G30001 uses C9TZ-13341-C.
I am fairly certain that the original wiring is set up on my truck.....what is the difference between these 2 parts?
Here was my translation:
<TABLE style="WIDTH: 268pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=358 x:str><COLGROUP><COL style="WIDTH: 83pt; mso-width-source: userset; mso-width-alt: 4059" width=111><COL style="WIDTH: 185pt; mso-width-source: userset; mso-width-alt: 9033" width=247><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 83pt; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25 height=17 width=111>Old Switch</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 185pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25 width=247>New Switch</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=17>BL/y</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24>BL/y</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=17>BL/br</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24>T/bk</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=17>WH/bl</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24>WH/bl</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=17>OR/bl</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24>Green</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=17>GR/wh</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24>GR/wh</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=17>Green</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24>R/bk</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=17>Blue</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24>Blue</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" height=17></TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8; mso-ignore: colspan" class=xl26 height=17 colSpan=2>Top row, left to right: OR/bl, WH/bl, GR/wh, BL/y</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8; mso-ignore: colspan" class=xl26 height=17 colSpan=2>Bottom row, left to right: Empty, BL/br, Green, Blue</TD></TR></TBODY></TABLE>
C9TZ-13341-C (replaced C5TZ-13341-A & B) .. T/S Switch / Available from Ford.
Applications: 1965/66 F100/250 2WD / 1966 F100 4WD / 1967/68 F100/350 / 1969 F100/350 before serial number G30,001.
D0TZ-13341-B .. T/S Switch / Obsolete
Applications: 1969 F100/350 from serial number G30,001 / 1970/72 F100/350.
The serial number is the last 6 digits of the VIN.
Compare the VIN on the Warranty Plate to the VIN on the registration to see if they match.
Peeps replaced damaged left doors with used doors. 99.9% of the time, they did not install the original Warranty Plate on the replaced door!
Whwn this occurres, the VIN and codes stamped on the Warranty Plate will no longer match the vehicle.
Originally Posted by HIO Silver
Check your Warranty Plate.
WhwnSic this occurresSic, the VIN and codes stamped on the Warranty Plate will no longer match the vehicle.
Your redundancy is confounding. Simply to punctuate your supposed correctness. Tiresome Billy Boy.
Btw, the PN is obsolete as OEM - not obsolete as reproduction. Why don't ya tell Dennis Carpenter that using Ford PNs is technically incorrect because it implies that it is an NOS part.
It's not a serial number.. it is a CONSECUTIVE UNIT NUMBER.
Compare/check... whatever.
Btw, the PN is obsolete as OEM It's available from Ford, Mr. Clueless- see below.- not obsolete as reproduction.
Uh huh, yeah right. You haven't a clue inre to what Ford parts catalogs state.
Get a copy of this catalog and look what it says on these pages inre to the Numerical Sequence of Assembly aka SERIAL NUMBER.
I've decoded over 800 VIN's for FTE members. The serial number is the last 5 digits 1948/60, last 6 digits 1961 thru today.
There are 10's of 1000's of part number listings in this catalog before/from certain serial numbers.
C9TZ-13341-C is AVAILABLE from Ford / Type the part number into either of FTE's Ford Dealer Parts Department sponsors websites.
MSRP: $61.98 / TousleyFordParts.com price: $40.91. // PartsGuyEd.com (Horizon Ford in Tukwila WA) price: $44.63.
If the part was obsolete, this would be listed: NO PARTS FOUND
Ten or so years ago, FoMoCo's corporate attorneys notified all the repro parts sellers, obsolete Ford dealers that they would have to pay a yearly license fee to use Ford, Ford Motor Company, FoMoCo, Edsel, Lincoln, Mercury, Fordson in their business names. To use Ford/Edsel/Lincoln/Mercury part numbers in their catalogs.
Most did not want to pay the fee, but Carpenter did. Carpenter's catalogs for the most part, follow the same part number sequence as Ford parts catalogs.
Since the genuine Ford switch is more expensive than Carpenter's price, Carpenter is selling a reproduction switch...since dealer net cost is $38.20.
Ridiculous, just ridiculous. Don't you think I would know what's correct since I was a Ford partsman for 35 years? You have ZERO Ford parts experience, so it's obvious you haven't a friggen clue.
And I listed ALL the applications for these two turn signal switches so members would be aware. How many applications did you list?
sic is latin, translates to thus in english / It is not supposed to be capitalized, Mr. spelling expert and you know what they say: People that live in glass houses shouldn't throw stones.
You could spend 24 hours a day, 7 days a week here on FTE just correcting spelling errors and typos. Read thru my 39,600 + other posts, see how many typos/spelling errors you can find. Lotsa luck, because there will be very few.
And btw, occurred is spelled correctly. Get a dictionary, Mr. spelling expert and look it up.
turn signal replacement
my original colum was a 69 f-250 but i replaced it with a 76 because the threads on top were buggered the po was drunk and tried to pull the wheel with a hammer would a turn signal switch from 69 still work in the 76 depending on the serial no? and buy the way good job bill your are a true professinal thanks.
911tom
12-08-2016 03:54 PM
jsnbuck
07-31-2012 06:29 PM
shillinghillf600
09-28-2010 08:26 PM
dan66tampa
01-23-2005 08:42 PM
