Rust repair project!!! Lots of Picture. My first attempt at body work.
I thought about it, but i couldn't find a decent cab that wasn't just as bad. And the rest of the cab is in pretty good shape, fenders are good hood is good drivers door is good passengers door is OK and the roof and floors are good other than drivers side. I know a lot of guys would scrap it, but its hard for me to do work like taking off a cab by myself in my driveway. So here we are haha! Im sure half way through I'll regret it.
Hows the radiator support ?
Its just cutting and welding a few pieces of pre-stamped steel, not like I have to fabricate each piece myself.
I am going to repair my cab, I appreciate it though! I have all the parts already and if it would stop raining I could have had it fixed today. If you need a second set of hands with your cab let me know. We are probably not that far away from each other, I know its hard to find help sometimes.
I'm sure you can get it done.
Mine wasn't much better. (and I have no one to blame but myself, lol)
Just take your time and do your best to square everything up before you weld it in.
The area up by the dimmer switch is a b!#*h because of the heavy reinforcement underneath.
The seatbelt mount is important for safety.
I decided to make a new one.
Weld through primer before and cold galvanizing after are both godsends.
I have to address the passenger side seam this spring.
some of you are the reason these trucks are dwindling. if you take 2 trucks to make one, over and over again, eventually you have no trucks left! its a little rust. as long as the rest of the truck is fine, its worth it. its welding in prefabbed pieces of steel. if you cant handle that, well then you probably have your oil changes done at jiffy-lube.
Weld Thru primer, Weld Through Primer, Cold Galvanizing Compound,Cold Galvanizing Spray,Cold Galvanizing Paint, Zinc Rich primer
Basically it is a spray of powdered zinc with a binder.
The zinc acts the same as the zinc anode on a boat and saves the steel by sacrificing itself first.
It also develops a passivated shell of zinc oxide to protect itself.
I don't want to deal with the BS at DMV trying to get my truck retitled as a composite vehicle, even if I can get the scrap title from the junkyard.
#29
#30
My current DD is white, also driving me nuts haha. I hadn't washed it in about 4 mos. Pollen, road salt, spent a weekend driving around dirt roads hunting with rain. And then someone threw a cup of black coffee at the back hatch in anger. 9 hours I worked with the car. The paint is much smoother to the touch. But, more than 10ft away the only place you can tell a difference is the trim and chrome.
CLiffs: flat black will only get so clean. Will look even dirtier when not clean. White will look the same no matter what. Think about fleet vehicles: what color are they?
